Cisc ISE problem with TACACS
umeshunited
Hi All,
I am having problem with my ISE  and legacy switches.
I have to delete switch and re add it to ISE in order to make TACACS work.
Is there any compatibility issue with legacy deivces ?
hslai
As you were able to get it to work by removing and re-adding the network devices to ISE, it's potentially an issue in ISE. Please open a TAC case to troubleshoot if the project later resumed and the problem continuing.
9 Replies 9
Nidhi
What is the switch model here ? you might want to check the data sheet for this switch.
as long as this switch supports TACACS+ functions, it will work with ISE.
Nidhi
What issue are you having?  There are many version of TACACS configs and TACACS has been around for many years.  All should work with ISE, but the syntax on the switch is different and what features of TACACS are supported are different depending on IOS version.
Hi Pual ,
We are having mix of old and new switches. So we have prepared two set of commands.
We are facing strange issue. We first added all switches in ISE. Now when we configure aaa on switch it won't work. We have to remove that switch and add it again in ISE then only it will work.
Also first we will try set-1 commands if it does not work we will go for set-2.
---------- Set - 1 (For latest IOS versions)--------------
 tacacs server AUTH
address ipv4 x.x.x.x
key KEYVALUE
aaa group server tacacs+ Tacacs_Server
server name AUTH
ip tacacs source-interface XXX
------------- Set -2 (Old versions)--------------
aaa group server tacacs TACACS_Servers
server x.x.x.x
tacacs-server host x.x.x.x key KEYVALUE
Hi Nidhi,
We have 3750 having code, 12.2 . After applying aaa configuration on switch it did not work. I had to remove switch from ISE and re added it.
Hi Nidhi,
Hello umeshunited,
Could you
1. What error shows or be more explicit when it says "it stops working"
2. The present problem is only with the legacy
3. You have new switches working with TACACS +
4. What version of Cisco ISE has running.
Thank you for your time, I am waiting to help.
Best regards,
Hi michaeljosuecruza
Client has currently paused ISE installation  , so as of now no progress from client.
Thank you.
hslai
thomas
It sounds like this is better handled as a troubleshooting session with TAC since you aren't providing enough useful details (switch configs, policy screenshots, etc.)
