Cisco 3650 tacacs+ with SSH works, not for http to use wireless GUI
Erik Boss
Last week I installed a brand new Cisco 3650 switch and the wireless option.
Everything works fine.
I also configured tacacs+. Login through SSH works fine.
Now I want to manage the wireless part from the GUI bij entering https://ip-address/wireless
Local authentication with priv 15 works fine.
Now I configured tacacs. After entering username password I received a blank screen.
After debugging, I got a SSl failed.
Mar  4 07:35:53.675: eah:  url=/wireless is for us with a secondary connection
Mar  4 07:35:53.675: eah: Secondary authentication required for realm priv_15_access
Mar  4 07:35:53.675: Tue, 04 Mar 2014 07:35:53 GMT <source address> /wireless auth_required
        Protocol = HTTP/1.1 Method = GET
Mar  4 07:35:53.675:
Mar  4 07:35:53.799: %HTTPS: SSL read fail (-6992)
Mar  4 07:35:58.400: eah:  url=/wireless is for us with a secondary connection
Mar  4 07:35:58.401: eah: Secondary authentication required for realm priv_15_access
Mar  4 07:35:58.401: HTTP AAA Login-Authentication List name: TACACS
Mar  4 07:35:58.401: TPLUS: Queuing AAA Authentication request 4673 for processing
Mar  4 07:35:58.401: TPLUS: processing authentication start request id 4673
Mar  4 07:35:58.401: TPLUS: Authentication start packet created for 4673(my username)
Mar  4 07:35:58.402: TPLUS: Using server <tacacs server IP>
Mar  4 07:35:58.407: TPLUS(00001241)/0/NB_WAIT/3AF752D4: Started 5 sec timeout
Mar  4 07:35:58.449: TPLUS(00001241)/0/NB_WAIT: socket event 2
Mar  4 07:35:58.450: TPLUS(00001241)/0/NB_WAIT: wrote entire 37 bytes request
Mar  4 07:35:58.450: TPLUS(00001241)/0/READ: socket event 1
Mar  4 07:35:58.450: TPLUS(00001241)/0/READ: Would block while reading
Mar  4 07:35:58.511: TPLUS(00001241)/0/READ: socket event 1
Mar  4 07:35:58.511: TPLUS(00001241)/0/READ: read entire 12 header bytes (expect 16 bytes data)
Mar  4 07:35:58.511: TPLUS(00001241)/0/READ: read entire 28 bytes response
Mar  4 07:35:58.511: TPLUS(00001241)/0/3AF752D4: Processing the reply packet
Mar  4 07:35:58.511: TPLUS: Received authen response status GET_PASSWORD (8)
Mar  4 07:35:58.512: TPLUS: Queuing AAA Authentication request 4673 for processing
Mar  4 07:35:58.512: TPLUS: processing authentication continue request id 4673
Mar  4 07:35:58.512: TPLUS: Authentication continue packet generated for 4673
Mar  4 07:35:58.512: TPLUS(00001241)/0/WRITE/3AFD3D3C: Started 5 sec timeout
Mar  4 07:35:58.512: TPLUS(00001241)/0/WRITE: wrote entire 26 bytes request
Mar  4 07:35:58.566: TPLUS(00001241)/0/READ: socket event 1
Mar  4 07:35:58.566: TPLUS(00001241)/0/READ: read entire 12 header bytes (expect 6 bytes data)
Mar  4 07:35:58.566: TPLUS(00001241)/0/READ: read entire 18 bytes response
Mar  4 07:35:58.567: TPLUS(00001241)/0/3AFD3D3C: Processing the reply packet
Mar  4 07:35:58.567: TPLUS: Received authen response status PASS (2)
Mar  4 07:35:58.656: HTTP: Priv level authorization success priv_level: 15
Mar  4 07:35:58.690: %HTTPS: SSL read fail (-6992)
Mar  4 07:35:59.096: eah:  urlhook called for url=/favicon.ico
Mar  4 07:35:59.096: eah: Not for us
Mar  4 07:35:59.097: eah:  urlhook called for url=/favicon.ico
Mar  4 07:35:59.097: eah: Not for us
So authentication seems fine to me.
Do I miss something in the ACS server?
Configuration for ip http login:
ip http secure-server
ip http authentication aaa login-authentication TACACS
ip http authentication aaa exec-authorization TACACS
ip http authentication aaa command-authorization 15 TACACS
Thanks!
Erik Boss
When I use IP HTTP then I got a blank page.
So this seems to be a fault in the selfsigned certificate.
But it won't give me a solution why i haven't any problems when I authenticate with a local account
hi Erik,
command auth is not supported for GUI for the IOS-XE boxes.
Also can you try dong the following to check if this is a config issue.
  1. I see that you have  used TACACS as a method-list. Can you try using “default”?
  2. To use “default”, you need to maje the following changes.
Aaa authentication login default  group  <server-grp>
Aaa authorization exec default group <server-grp>
On the http front, remove all the commands that you have configured below and only have this
Ip http authentication aaa
Can you paste the o/p of the folllowing commands?
sh run | sec http
sh run | sec aaa
Does http work instead of https?
