Cisco 3850 switches - IP Address Delayed for 802.1x and MAB Devices
jmins
Hi, we have several Cisco 3850 switches (WS-C3850-48P) that are all experiencing the same issue with various devices.  We have printers and laptops that take several minutes to obtain an IP address.  Sometimes the radius server sees the devices successfully authenticate in logs and sometimes not even when it eventually receives an IP address. The printers are MAB devices and the laptops are 802.1x.  We're not sure if this is related to the radius server, the switch configuration, or both.  Any idea what could be causing this delay?
Below are the switch port configurations:
Printers
switchport access vlan 100
switchport mode access
switchport port-security maximum 3
authentication host-mode multi-auth
authentication order dot1x mab
authentication priority mab dot1x
authentication port-control auto
authentication violation replace
mab
dot1x pae authenticator
storm-control broadcast level 80.00
storm-control action shutdown
auto qos trust
 spanning-tree portfast
service-policy input AutoQos-4.0-Trust-Cos-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
Laptops
switchport access vlan 130
switchport voice vlan 132
access-session host-mode multi-domain
access-session closed
access-session port-control auto
mab
auto qos trust
service-policy type control subscriber POLICY_Gi1/0/30
end
6 Replies 6
Rodrigo Diaz
hello @jmins , the authentication in terms of dot1x and mab is done at layer 2 hence it's not necessary for the supplicant to have initially an IP address to start the authentication process as the switch will handle the radius session related to the switchport.
The default behavior of a a switchport with dot1x is the following: it will receive EAPol packets to forward the authentication to the server, when the authentication finishes and it's successful,  the DHCP, TCP, and more connections will be allowed as it's displayed in this image , for your reference Wired 802.1X Deployment Guide
The ISE or Radius server  will update the endpoint with the IP once the supplicant gets/updates the IP with a feature called device-tracking, hence if you want to see accurate IP-MAC relationship in the ISE it's important that you have that feature configured.
Once clarified the last points, I would check the reason of failure of the endpoints authentication failure in the cases you mention, and for the delay in the endpoints authenticated I would place a capture to verify that the DORA process with your DHCP server is completed.
Let me know if it was helpful.
jmins
Hi Rodrigo,
Thank you for the information.  However, I am not using ISE so I'm not sure if that "device-tracking" feature applies here.  We have various sites and this is the only site with these switches that are experiencing significant delays in receiving an IP address.
There are a lot of possible issues. but the ones you need to look at is how are the devices getting DHCP?
Do you have a server on site, or is it at a home office location?
Do the devices stay on the same network, or are you changing vlans?
Do you have any type of DHCP snooping in place, and if so are all the uplinks trusted?
Do you have the helpers set on the default gateway?
As Rodrigo stated, 802.1x and MAB don't require the IP address, so if you are seeing issues there also there could be issues in the data path causing issues. You would need to check your RADIUS logs to see if the requests are coming in, and for DHCP look to see if a request comes in and an offer sent.
Each switch is configured with its own DHCP pool. For instance, a switch located on a specific floor would be set up as follows:
ip dhcp pool Desktops network 10.30.34.0 255.255.254.0 option 130 ip 10.50.0.21 10.50.0.20 10.50.1.21 default-router 10.30.54.1 dns-server 10.103.232.180 10.203.100.10 10.113.253.180 domain-name avidxchange.com
The interface vlan on that device is assigned the IP address 10.30.54.1 with a subnet mask of 255.255.254.0. The 5W printer connected to that switch is on vlan.
This issue persists whether or not a DHCP reservation is in place, and there are no IP address helper or DHCP snooping configurations in effect.
switchport port-security maximum 3 <- the port secuirty is not recommend at all with dot1x
access-session host-mode multi-domain <- why multi-domain you need to make it multi-auth instead.
We tried removing the port security and changed the host modes previously to no avail.
