Bookmark
Subscribe
2471
Cisco ACS view-alertmanager and view-logprocessor Not running
SupportAC
Hi ,
We have in our cisco ACS the processes view-alertmanager and view-logprocessor in state not running.
I tried to stop and start the procesess but same result. Any another idea?
Do Someone knows what is the function of this processes and what implies they aren“t running?
5 Replies 5
balaji.bandi
Try below commands from the command level see if you can able to fix the issue.
>application acs stop
>application acs start
if the problem still persists, if you have maintenance windows, reboot and let us know.
here is some more information for reference :
https://www.cisco.com/c/en/us/support/docs/security/secure-access-control-system/113485-acs5x-tshoot.html#p62
BB
Stop and start the processes didn“t work.
I“ll try to schedule a time window to reset the devices.
One question, do you know what are the functions of this procesess?
Thanks anyway,  I see it before but this guide donĀ“t explain to me the purposes and relevance of this process. And what imply that they arenĀ“t running
it is self explanatory on  table 8 ACS Log
if those not running, you would not get the expected log for reporting and alerts
MonitoringAndReportingAlert.log
Stores the logs from view-alertmanager process.
MonitoringAndReportingCollector.log
Stores the logs from view-logprocessor process.
BB
