Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco ASA and downlodable acl problem
HI,all
Can somebody shed some light on how to configure ACS for downloading user base acl.
We have used TACCAS for remote access user authentication.
Do I required any config on ASA or i have to just configure Policy element /authorisation profile  and bind that profile with user?
thanks in advance
Configuration Example.
camejia
Level 3
Level 3
Hello Sandeep,
First of all, if you are using TACACS+ for VPN Remote Access then Downloadable ACL's are not supported. You might need to change the ASA configuration to use RADIUS as the authentication protocol instead.
I am attaching a configuration example to this post.
Hope this helps.
Dear Carlos,
Thanks for reply.
That mean i have to change authentication method RADIUS for remot access vpn users and also I have to use radius for authorizaton.
Hello Sandeep,
You are right. RADIUS includes Authentication/Authorization on the same packet which causes the authentication response from the RADIUS server to include the Authorization Attributes as well.
Regards.
