Cisco ASA with Aruba ClearPass RADIUS+NAC need help!
davidsonyo
Greetings,
We have an ASA 5525 (9.4.3 IOS) and an Aruba ClearPass server. We terminate an IPSec remote VPN on the ASA with RADIUS authentication and then a NAC checking from the ClearPass server.
The RADIUS and the NAC process is successful but after that nothing happen.
How can we use the proper rule concerning for the user?
The ClearPass tried to send a REAUTH COA message for the ASA but nothing happened. We tried to send DACL from ClearPass but also nothing happened.
What should send the ClearPass for the ASA? To deeply understand the methodology behind this with a Cisco ACS scenario what would the ACS send to the ASA as an exmaple ?
Is anyone familiar with this or can help ?
Any help is appreciated very much!
Thanks in advance!
David.
Florin Barhala
Level 6
Level 6
Did you solve this in the meantime?
I can think of aaa-server CoA configuration to be checked.
I'm having a similar issue. Do you or do you know of someone that has information on this issue?
