Cisco IP Phone Authentication on ISE 2.3 using MD5 on HPE Comware switch
B. BELHADJ
Level 4
Level 4
Dear all
I have a new behavior with ISE and HPE Comware swicth when trying to authenticate Cisco IP Phone on the network using MD5.
I configured Authorization Profile named "VLANTOIP" with these attributes:
Access Type = ACCESS_ACCEPT
Egress-VLAN-Name = 1:VLAN-TOIP
H3C_AV_PAIR = device-traffic-class=voice
Tunnel-Medium-Type = 1:6 // This line is translated in ISE to indicate 802
Tunnel-Type = 1:13 // This line is translated in ISE to indicateVLAN
All other Authentication policies and Authorization Policies configuration are correct.
When the Phone try to access to the network, it is rejected by the AUthorization Profile and ISE says:
15039 Rejected per authorization profile
Selected Authorization Profile contains ACCESS_REJECT attribute
Authorization profile/s specified are not suited for this Network Access Device
The same configuration in ACS 5.8.1.4 is working fine!
My question is:
  1. 1. Why this configuration works with ACS and not with ISE?
  2. 2. Why when I change the "H3C_AV_PAIR = device-traffic-class=voice" attribute to "cisco-av-pair = device-traffic-class=voice" and "Egress-VLAN-Name = 1:VLAN-TOIP" to "Tunnel-Private-Group-ID = 1:VLAN-TOIP" the IP Phone can access the network without issue?
Any reply will be appreciated!
Best regard
2 Accepted Solutions
paul
Level 10
Level 10
I haven't worked with non-Cisco switches before so this is just a guess.  In your Network Device definition of the switch did you set it to an HP device profile?  That is the only spot I can think of that ISE would have awareness of the type of NAD device.
Hi paul@berbee
Thank you for your reply. It was helpeful.
The issue was not in the NAD profile (I can choose every profile).
It was an issu on the Authorization Profile that I created with HPWired Profile. Because this is a Comware OS, i chosen Any as "Network Device Profile" in the Authorization Profile and it worked well.
But the necessary attributes must be added in the "Advanced Attributes Settings".
Best regards
7 Replies 7
paul
Level 10
Level 10
Hi paul@berbee
Best regards
I am not finding H3C_AV_PAIR attribute in ISE. If you imported it or modified an existing RADIUS vendor dictionary, please provide a copy.
Is HPWired selected as the NAD profile in the NAD definition for this switch?
I've not been able to see "Rejected per authorization profile". Instead, HP:Egress-VLAN-Name is not showing up if I enabled "Allow Tagging"; HP:Egress-VLAN-Name is showing up if disabled "Allow Tagging" but not properly, either:
Egress-VLAN-Name = "1:VLAN-TOIP"
Tunnel-Type:1 = VLAN
Tunnel-Medium-Type:1 = IEEE-802
BTW, is your ISE 2.3 upgraded from a previous release? Did you use the migration tool to import ACS 5.8 data to ISE?
It is critical that the Authorization Profile be set to 'Any' or to specific NAD Profile  AND  that the intended matching Authorization Policy Rule includes reference to the Authorization Profile which has been flagged as Any or Specific Profile name.  Otherwise, the rule may match, but will not find a compatible NAD profile.
Realize that you can overload the Permissions list with multiple AuthZ Profiles such that it can match NAD Profile for Cisco OR HP or Any.  Typically 'Any' would be used as a single entry versus multiple listing for specific NAD profiles.
/Craig
Hello Hslai
Yes the H3C_AV_PAIR attribute is a modified attribute in ISE (previously added to the ACS 5.8.1.4 configuration). In attachment a capture for that.
Yes HPWired is selected as the NAD profile in the NAD definition for this switch but you can choose another one.
As I mentioned previously the issue was in the Profile defined in the  "Network Device Profile" in the Authorization Profile. Because the switch uses the Comware OS I choosed Any in the Profile.
==> Yes
If the HPWired profile does not match the requirements for Comware based model, then duplicate or create new profile and make necessary changes such as RADIUS dictionaries, CoA settings etc.  Any option is a bit more flexible for handling multiple NAD profiles, but will be limited in what it offers in Common tasks.
If it is matching the correct AuthZ policy rule and AuthZ Profile and still failing, then may be issue with the attributes itself.  I would try returning same attribute in a simple policy for a Cisco device and see if it returns same error.
Again, make sure the NAD Profile includes the RADIUS dictionary that holds special attribute for vendor-specific NAD profile.
Hello Chyps
I have already resolved the issue. Please refer to my previous comments.
Best regards
