06-14-2017 04:30 AM - edited 03-11-2019 12:47 AM
Hi Guys;
I am running Cisco ISE 1.2 on a VM (soon to be upgraded), I have come to it today and it is stating the license has expired. I am not sure how this can have happened as we only have BASE licenses and this shouldn't expire? Any thoughts appreciated?
John
06-14-2017 08:01 AM
Are they possibly 1.2 mobility licenses? I recall those are term licenses - even for the Base component.
06-14-2017 09:32 AM
Hi Marvin;
That is a possibility, I will try and find out but it may be hard as locked out now.
I have another cluster which was upgraded to 1.4 and shows as perpetual, would the licensing change on an upgrade?
Cheers
John
06-15-2017 02:16 AM
Upgrade does not change Base licenses. The old Advanced license type will change to equal numbers of Plus and Apex.
