Cisco ISE 2.3 problems with retrieving groups in Active Directory
Hello security fellows,
today i faced strange problem. Deployed ISE 2.3 for PoC and I had issues pretty straight after the installation-I tried to join the ISE to the Active Directory domain, everything was ok, the join point was marked Succesful/Operational, but when I go and try to browse groups - nothing is found.
In the same environment ISE 2.2 is working perfectly.
Does anyone had such issue? Does Cisco implemented something differently according AD?
Best regards!
Ditto that.  But I saw that only when I browsed to ISE 2.3 with IE 11 and then I couldn't see any Groups.
When I open a Firefox browser to the same node and Add Groups, they all appear almost immediately.
9 Replies 9
paul
Level 10
Level 10
This is funny.  I had the exact same problem on my fresh ISE 2.3 install using the 3515 OVA 600 GB file.  If you to a test user lookup the groups are all there.  We ended up adding the groups in manually.  If you do the test user you can see the group format ISE is expecting.
I have done two other 2.3 installs with no issues in adding AD groups via searches.
Just a follow up I installed the 3515 200 GB in my lab a few days ago and it doesn't have this problem.  My lab AD environment if very small.  I know the customer where I had this issue has a large # of AD groups.
Yes, I used the exact same image!
I Even had problems with test user function... Definetely there is something not right.
Ahh great catch.  Just tested with my lab and IE doesn't work for group retrieval.  Firefox and Chrome work perfectly.  I always use Chrome, but the customer that was running the Webex on Friday was using IE.
Good to know.
Yes, probably is the IE. I'll try other browsers, but i think the customer tested with Firefox and the situation was the same.
Wow cannot believe just by changing browser fixed my issue!!!
Thank you for sharing you rock!!!
Wow.......thanks. If only I came across this post 5 hours ago, I would've saved me precisely 4 hours and 59 minutes.
hslai
CSCvf93841
opened to track this issue. It might not be externally visible for 1 or 2 days.
