Cisco ISE configuring Command sets for switches
CSCO12190770
Trying to permit interface range in command set for allowing particular port to be accessed other should be blocked. I Tried
FastEthernet 0/([1-9]|1[0-9]|2[0-9]|3[0-9]|4[0-7])$
It's not working. Tried to allow show running-config interface 0/1 to 0/47. Interface 0/48 should be blocked. how to write command sets for this.
Advance Thank for your help.
naveen.r.b
CSCO12190770
I tried...
Grant               Command                   Arguments
Permit              interface                       fa* [0]/[0-22]
Command authorization failed trying to get to any interface
Permit              interface                       fa* 0/*
Allows access to any interface
Permit              interface                       fa* 0/[0-22]
Permit              interface                       fa* 0/0-22
So if you can point me in the right direction on the wildcards in the arguments statement, if you can provide an example of how you would only allow access to to fa 0/1 - 46 and fa 0/47-48 should be blocked for example...
