Cisco ISE Counter for Authenticated Guests does not count up
Marco Serato
Hello community
We have built a Cisco ISE guest portal (sponsored portal) with login. In addition a Cisco WLC, which redirects the guests to the Cisco ISE portal. The authentication of the guests works without any problems. Unfortunately, the Authenticated Guest Counter remains at 0 and simply does not count up.
Does anyone have any idea what might be missing or not configured?
Many thanks
20 Replies 20
Nothing can be seen today in the live log for the last 24 hours for the WLC and Failed Auth & Session.
In the Report -> Endpoint & Users -> RADIUS Accounting you can see that 3 weeks ago there was still data for Accounting Start, Stop & Interim Update. But that was 3 weeks ago. No current data.
Can an accounting be triggered on the WLC via CLI?
get it, WLC is not send account anymore I think
check if FW block ports
what is WLC platform you have ?
MHM
You can’t trigger accounting. You can trigger a test aaa authentication but that does not involve accounting. You need an active session to cause accounting to work.
Have you tried running a monitor capture session on the outgoing interface on the WLC?
Please share output of
show run | section radius
show run | include aaa
Details are important. What IOS-XE version? Maybe there is a bug?
Marco Serato
Hello community
I still owe you an answer. We have updated to the latest version and since then the problem is gone. Seems to have been a problem in the version.
Sorry I pass your authority and select your last reply as solution.
Now can you check if radius account work after upgrading?
Thanks  a lot for update us
MHM
Everything done correctly. Accounting continues to run smoothly.
