11-07-2017 04:04 AM - edited 02-21-2020 10:38 AM
i am using Cisco ISE 2.3 with this patch (ise-patchbundle-2.3.0.298-Patch1-221230.SPA.x86_64.tar) in My lab for Dot1x Authentication , every things is ok but sometimes users can not login to network and on the switch side i see failed authentication and on the radius live log does not see any new log while this user account and policy set on ISE are ok , after manually stop and start ise application services every things are ok , i used AD for user accounts Data base. another things i should say is in problem time if i chek radius connectivity with NAD via test aaa group .... the authentication is Pass and i can its log on radius live log,can any one help me?
11-07-2017 02:48 PM
Hi Ahmed
Looking at your patch1 version number, it looks like you have the "old patch 1" that Cisco subsequently removed from the CCO Download page. They replaced it with ise-patchbundle-2.3.0.298-Patch1-221754.SPA.x86_64.tar.gz. Not sure if that is your problem. The New Release Notes state
Note We have recalled ISE 2.3 patch 1 due to an issue we found after posting. An updated patch file has been reposted, and the new file name is ise-patchbundle-2.3.0.298-Patch1-221754.SPA.x86_64.tar.gz. If you already installed the previously posted patch, you MUST uninstall that patch, and install the new one.
11-07-2017 10:02 PM
Thanks Man. i remove patch and change it to ise-patchbundle-2.3.0.298-Patch1-221754.SPA.x86_64.tar, i will test again and advise you as soon as possible.
04-04-2018 11:30 AM
Hello Ahmed
I experience the same problem.
I see failed Dot1x Auths on the Switch-Side, but I don't see any entries on the ISE-Live-Logs - they won't appear.
I run ISE 2.3 Patch 2.
I will upgrade ISE to 2.4 to look if the Problem is still there.
Did you fix the problem?
Best Regards
Michael
