Cisco ISE FlexAuth with 802.1X PCs and IP Phones as MAB multi-domain Q?
Nicholas Poole
Im trying to follow the trustsec 2.1 guide on IP Phones into LowImpact mode.
I can get a PC on its own to authenticate via dot1x/tls
I can get a Cisco IP Phone on its own to authenticate via MAB.
When the two are on the same switchport, the phone will authenticate but not the PC.  ISE logs EAP timeouts.
The switchport has the LowImpact port ACL of
ip access-group ACL-DEFAULT in
The IP Phone gets a dACL that allows it ok.
I assume MAB phone and dot1x PC is supported?  Any ideas?
Thanks in advance.
13 Replies 13
Richard Atkin
Level 4
Level 4
What you're doing is fully supported. Can you please post your switchport Config and what software you're using on the switch and ISE?
The switch port config is:
interface GigabitEthernet1/0/12
switchport mode access
switchport voice vlan 3
load-interval 30
srr-queue bandwidth share 1 30 35 5
priority-queue out
authentication event fail action next-method
authentication event server dead action reinitialize vlan 1
authentication event server alive action reinitialize
authentication host-mode multi-domain
authentication open
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication violation restrict
mab
mls qos trust dscp
dot1x pae authenticator
dot1x timeout tx-period 10
spanning-tree portfast
end
C3750G-24P#sh ip access
C3750G-24P#sh ip access-lists ACL-DEFAULT
Extended IP access list ACL-DEFAULT
    10 permit udp any eq bootpc any eq bootps
    20 permit udp any any eq domain
    30 permit icmp any any
    40 permit udp any any eq tftp
    50 deny ip any any log
It was on 12.2.58 last release and i moved it to 15.0(2)SE3 just in case but no difference observed.
ISE is 1.1.3
Thanks Richard
The ISE AuthN policy is basically use anything.
The ISE AuthZ policy is:
  • MAB IP Phone = Voice Domain & permit ip any any
  • Domain User = permit ip any any
  • Domain Computer = permit ip any any
  • MAB Computers (including the tested PC) = permit ip any [RFC1918]
If the MAB Computers is disabled the PC does not Authenticate if its attached to an authenticated phone.
If the MAB Computers is enabled the PC will match it after reporting EAP timeouts of 120 seconds.
As a side comment:
I was testing an IP Phone with EAP-MD5 instead of MAB yesterday (I dont have a CUCM system to test full certs for TLS).  I got the phone to authn only after tweaking the Allowed Protocol preference, but this had problems with the Domain PC authn which is why i posted another Q yesterday about multi EAP authn methods with ISE yesterday.
Below is the ISE log showing from bottom up.  Machine Auth fail, IP Phone then succeeding via MAB, the computer matching via MAB failover, and then the Domain User auth failing once I log into the machine.
I cant seem to find a good example of an IP Phone test in TrustSec 2.1 (but its multi document style doesnt make it easier to find things) so I am looking at other references for help, including the TS2.0, IBNS and other docs including another forum post: Deploying 802.1x when workstations are connected behind IP phones
(https://supportforums.cisco.com/docs/DOC-22478)
Which has the following line in it:  "The only caveat that you need to be aware of is that once MAB is  enabled, it applies to both the data VLAN as well as the voice VLAN. If  the workstation does not respond to the EAP packets, its MAC address  will be used to try and authenticate it."
Which almost sounds to me like that once MAB is used by the IP Phone it means MAB has to be used by the data domain device too?
After seeing your ISE logs it says "no response received after 120 seconds". If you click for details, most probably you will find that this is an authentication error. Could you share what are your authentication rules?
Cisco IP Phone is using MAB only because 802.1x is failing. The same goes to the workstation, since 802.1x is failing then it uses MAB. But both processes are completely independent
Please rate if it helps
The IP Phone isnt using MAB as dot1x if failing, its not setup to use 802.1X.  Im following the trustsec 2.1 design guidw where its using MAB for IP Phones.
I deduced that because of your switchport configuration
Even if a device is not configured with 802.1x, your switchport is and so the switch will try 802.1x first toauthenticate any device and only if it fails (after the 802.1x timer and retries expire) the switchport will use mab.
But back to your issue, when using "authentication host-mode multi-domain" every device connected to the switchport will authenticate independently, so the ip phone authentication won't interfere with your PC authentication.
Your ISE logs say "no response received after 120 seconds". If you click for details, most probably you will find that this is an authentication error. It wil be great to see the details of this log and also what are your authentication rules.
The ISE log detailed steps are as follows:
Steps
11001  Received RADIUS Access-Request
11017  RADIUS created a new session
Evaluating Service Selection Policy
15048  Queried PIP
15048  Queried PIP
15004  Matched rule
11507  Extracted EAP-Response/Identity
12300  Prepared EAP-Request proposing PEAP with challenge
12625  Valid EAP-Key-Name attribute received
11006  Returned RADIUS Access-Challenge
11018  RADIUS is re-using an existing session
12501  Extracted EAP-Response/NAK requesting to use EAP-TLS instead
12500  Prepared EAP-Request proposing EAP-TLS with challenge
12502  Extracted EAP-Response containing EAP-TLS challenge-response and accepting EAP-TLS as negotiated
12800  Extracted first TLS record; TLS handshake started
12805  Extracted TLS ClientHello message
12806  Prepared TLS ServerHello message
12807  Prepared TLS Certificate message
12809  Prepared TLS CertificateRequest message
12505  Prepared EAP-Request with another EAP-TLS challenge
12504  Extracted EAP-Response containing EAP-TLS challenge-response
5411  No response received during 120 seconds on last EAP message sent to the client
Nicholas Poole
As a reminder of the situation I am still facing.
TEST 1.  I connect my Win7 PC that is setup to use EAP TLS, 802.1x authentication works as recorded in Windows and in the ISE log.  Therefore there are no Windows supplicant issues.
TEST 2.  I connect a Cisco 7942 IP Phone only to the switchport, authentication via MAB to the voice domain works as expected.
TEST 3.  I connect the IP Phone and it works via MAB, I then plug the PC via the phone but the PC is failing to authenticate with EAP-TLS with the EAP timeouts as listed before.
TEST 4.  I connect the IP Phone and it works via MAB, I then plug the PC via the  phone but change from TLS to PEAP, and the PC authenticates successfully.
Anybody seen this behavious before?  Any ideas at all?
According to your issue can you confirm that your client has a certificate because if you would like to use EAP-TLS you need to have a certifcates on both sites.
In log it looks like the client didn't sent its sertificate if any ?
Is the PC port enabled on the IP phone?
Try to replace the phone. It is quite likely that it fails to relay EAP frames.
Did you resolve your problem to authenticate PC by EAP-TLS connected to phone port?
