Cisco SGT ACL and Trustsec on switches
carl_townshend
Hi Guys
I have some questions around SG ACLs and Trustsec
1.We have a mix of 9200 / 9300 / 2960X / 2960CX / 4500x switches, do these support SGT, inline taging, SXP and SGACLs ?
2.Is there a limitation to the size of SGACL we can use on the switches? We were going to use normal ACLs with our third party NAC solution to try and do some kind of segmentation policies, however there were certain TCAM limitations, so we did not do this, are these same limitations there when using SGACLs, or are they more efficient?
3.Has anyone successfully used a third party solution to assign SGTs etc?
Cheers
Carl
balaji.bandi
1. You can find the Matrix here with IOS code required as base to work SGT/SXP :
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise-networks/trustsec/software-system-bulletin.pdf
2. you can find this information based on the device models
3. I have not tried it - as long as they are standards that should work technically - if you using 3rd party their document can explain how to use it.
BB
