Cisco vWLC and Central Web Authetication ISE Issue
Yuriy Dyshlevoy
Hello!
I have an issue with Wireless Central Web Authentication. Wired CWA woking fine.
My APs woking in FlexConnect mode with local switching. When I connect to the WLAN with CWA, web page with guest portal in not opening, but I see, that redirect is working...
When I try to ping ISE, and have a strange result:
y@5733Z:~$ ping 10.10.2.47
PING 10.10.2.47 (10.10.2.47) 56(84) bytes of data.
64 bytes from 10.10.2.47: icmp_seq=5 ttl=63 time=1.45 ms
64 bytes from 10.10.2.47: icmp_seq=8 ttl=63 time=2.22 ms
64 bytes from 10.10.2.47: icmp_seq=10 ttl=63 time=1.43 ms
^C
--- 10.10.2.47 ping statistics ---
21 packets transmitted, 3 received, 85% packet loss, time 20106ms
rtt min/avg/max/mdev = 1.430/1.703/2.223/0.367 ms
When I change the security method on the WLAN to open or any other, ping to ISE working fine. Please help!
nspasov
Central Web Auth (CWA) works different on controllers/APs running in FlexConnect mode. Please check this guide and confirm that you have similar setup.
http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/116087-configure-cwa-wlc-ise-00.html
If so, please post screen shots with your configs (Redirect ACLs, policies in ISE and the WLC SSD settings).
Also, the version of code that you are running in ISE and your controller.
Thank you for rating helpful posts!
6 Replies 6
nspasov
Venkatesh Attuluri
this can be a issue with redirection ACL..make sure correct ACL is pushed and DNS is permitted
Yuriy Dyshlevoy
The reason of this is bug CSCuo39416
https://tools.cisco.com/quickview/bug/CSCuo39416
Yuriy, thank you for following up on this thread and for posting the bug (+5 from me). Is there no resolution at this point? For instance, will upgrading to 8.x address the issue?
Neno, I have resolved my problem by the upgrade to the 8.0.120.0 version.
Some details for this Bug:
https://tools.cisco.com/bugsearch/bug/CSCuo39416/?referring_site=bugquickviewclick
Blah, sorry about that...for some reason the bud details did not load properly when I first opened the link!
Thanks again for providing the details and for posting the bug
Now since the issue is resolved, you should mark the thread as "answered" :)
