Client Provisioning behavior with both wired and wireless profiles
erajca
Experts,
When using a wired BYOD policy rule referencing a Native Supplicant Profile that has both wired and wireless profiles configured why the wireless profile doesn't get configured on the endpoint as well. Is this normal behavior ? Should I be separating wired and wireless profiles ?
Ed
hariholla
Currently on-boarding requires the Network adapters connect to network separately. If both NICs are connected to the network together, then on-boarding happens at the same time. Did you check if the supplicant is provisioned when connected to wireless network?
We have only tested separately with wired and wireless NICs successfully by disabling one while testing with the other however when enabling both NICs and onboarding with wired, the wireless SSID profile doesn't get pushed out to the client.
hslai
If the client endpoint is running Windows OS, I believe it's expected behavior that NSA only configures the connected wired interface.
