CoA not supported for an endpoint
networker4424
I have integrated a Pica8 switch with latest version of ISE, all seems fine but CoA operation for port bounce is not working.
Its worth mentioning that CoA works fine for reauthenticate and other functions just the CoA port bounce feature is giving this error. And we had this problem from the very start, its not like that it worked previously but stopped later. Any suggestions on how to fix it would be greatly appreciated.
Ali
15 Replies 15
How did you manage to do port-bounce? Did you modify or add anything in the NAD profile?
Maybe something missing there.
Do you have a tac case open?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
