configuring ISR 4331 with RADIUS authentication using management interface
efarkhondeh
Community Member
I have a ISR 4331 router, I configured have configured it so I can sign on using a RADIUS server. I have also made sure the ip ftp source-interface gigabitethernet 0" is the correct interface. Also, i have added the following configuration "
aaa group server radius name    ip vrf forwarding Mgmt-intf"
Lgos: Request timed out!
.Jul 16 03:51:21.863: %RADIUS-4-RADIUS_DEAD: RADIUS server xxx.xxx.xxx.xxx 8:1812,1813 is not responding.
.Jul 16 03:51:21.863: %RADIUS-4-RADIUS_ALIVE: RADIUS server xxx.xxx.xxx.xxx:1812,1813 is being marked alive. I cannot ping the radius server unless I use ping vrf Mgmt-intf xxx.xxx.xxx.xxx.  I know the RADIUS server config is good since all of our switches are working correctly. Any help is appreciated.
Not sure why you are using ip ftp source command for radius.
This should work (if you can ping using the vrf interface and you don't
have an rule to block radius ports)
ip radius source-interface Vlan11 vrf test-vrf
aaa group server radius test-radius
server name test-srv
ip vrf forwarding test-vrf
radius server test-srv
address ipv4 10.10.10.7 auth-port 1812 acct-port 1813
This is my config which is similar to yours but it is not working:
aaa group server radius our_name
sh r
aaa authentication login default group radius local
aaa authentication login console-auth local
interface GigabitEthernet0
ip address xxx.xxx.xxx.xxx 255.255.255.0
negotiation auto
ip radius source-interface GigabitEthernet0
radius server Our_server
address ipv4 xxx.xxx.xxx.xxx auth-port 1812 acct-port 1813
key our_key
This is an old topic... but...
should be...
aaa authentication login default group our_name local
