Configuring MFA for wireless users with ISE
SMD28316
Is it supported to configure MFA for wireless users? So far I see only documents for VPN clients, if yes, can I use a solution other than DUO like MS authenticator?
I'm using ISE 2.6 P 9
balaji.bandi
I know this is possible - but never deploy myself (since we use other method certificate and AD authentication for Wireless)
https://community.cisco.com/t5/security-documents/two-factor-authentication-on-ise-2fa-on-ise/ta-p/3636120#toc-hId-1184695435
BB
Greg Gibbs
See a similar discussion here:
Dual Factor authentication for office Wi-FI
