csacs solution engine static routes
tasneemjan
Frequent Visitor
Frequent Visitor
Is it possible to add a static route on on CSACS SE 1113 appliance. I checked all the CLI commands but couldn't find one.
kind regards
Jagdeep Gambhir
Level 11
Level 11
ACS appliance do not have a routing capabilities. It will use default gateway for communication.
~JG
Do rate helpful posts
