CSCwh73915 - Static IP Assignment not working -solution
kothare
CSCwh73915 - Static IP Assignment not working using attribute msRADIUSFramedIPAddress when posture is enabled.
Solution:
We can assign static IP, if we use  parameter radius ip address= msRADIUSFramedIPAddress in Posture unknown  authorization profile.
Then there is no need to  assign the radius ip address parameter in COA Authorization  .
I have tested  and its working fine.
1. posture unknown authz  profile  have parameter  radius ip address= msRADIUSFramedIPAddress.  --> Will have same static IP for that user
2.once its complaince , COA , authz profile - required  applied.
