Devices do not connect to WIFI
I have a deployment of ISE for devices who connect to WIFI through MDM.
The certificates are installed normally but they cannot connect.
Logs from ISE show "5400 Authentication Failed" followed by
As I can see the authentication is successful, and the authorization fails.
I will check the auth policy.
Do you have any other idea what could l check?
Konstantinos
Yes, there were hits in the default rule which denied access.
The problem was that the MDM was disabled for some reason in ISE. When I enabled it worked.
Thanks and regards,
Konstantinos
Colby LeMaire
It looks like authentication is successful and you are NOT matching any rule in the authorization policy.  Or you are hitting a rule in the authorization policy that has the result of "Deny Access".  Double check your authorization policy rules.
Thanks and regards,
Konstantinos
