Differentiation of ACS for Windows and ACS Solution Engine
snakayama
Level 3
Level 3
Hi everyone,
I have a question about the differentiation of ACS for Windows and
ACS Solution Engine.
Software version of each is;
ACS for Windows 4.0
ACS Solution Engine 4.1.1 build 23
and I access ACS Solution Engine via WEB console (http access).
- Differentiation One:
On the ACS for Windows, I can configure the setting of log file in
"Log File Management", such as,
Every day
Every week
Every month
When size is greater than xxxx
But on the ACS Solution Engine 23, the "Log File Management"
is not displayed.
So I can not configure the log setting which can configure on ACS for Windows.
- Differentiation Two:
On the ACS for Windows, the log information of "Network Access Restrictions
(NAR)" is displayed under "Network Access Restrictions (NAR)" field.
But on the ACS Solution Engine 23, the log information of
"Network Access Restrictions (NAR)" is not displayed under
- Differentiation Three
On the ACS for Windows, the log information of "TACACS+ Administration"
is displayed under "TACACS+ Administration" field.
"TACACS+ Administration" is not displayed under "TACACS+ Administration"
field.
Summary of above is as follows
Log File Management
ACS for Windows Displayed(Exist)
ACS Solution Engine Not Displayed(Not Exit)
Network Access Restrictions Log
TACACS+ Administration Log
I think this differentiation is normal behavior and if I get ACS Solution
Engine displayed same parameters and log information, I should use ACS
Remote Agent and I should access ACS Solution Engine via Remote Agent not
WEB console.
Is my understanding correct ?
If fact, this question is given me from my customer, however I have only
ACS Solution Engine 3.3 and not have 4.1 in my lab and ACS Solution
Engine 3.3 does not support Remote Agent.
So I can not confirm whether Remote Agent is the resolution or not of this
question.
Your information would be greatly appreciated.
Best regards,
darpotter
Level 5
Level 5
There are in fact very few differences between SW and appliance versions of ACS wrt functionality.
Mostly they are restricted to the non-availability of things that require 3rd party dlls (eg ODBC, RSA)
All of the points listed above look like issues with features not being enabled under the Interface Settings.
We did just notice that 4.1 renamed a whole load of logging attributes (GRRR) so anyone with scripts built around their CSV logs might need to do some rework after a 4.1 upgrade.
addendum... the appliance does have hard coded log/directory management - set to 10MB rollover.
