Guest Wireless Not Redirecting 2.3
kamlenegi
Hello All,
Can someone give me some troubleshooting steps for wireless guest redirect is not happening.
It was working perfect but suddenly last 2-3 days, it is stuck.
There is no change in existing network. After connecting guest ssid, nslookup is not happening for public sites.
Kamlesh
Jason Kunst
This doesn’t sound like ise issue if dns lookup not happening. Perhaps acl being applied on NAD? Network issue?
Have you contacted tac to help you troubleshoot? They are used for break fix priority.
Jason Kunst
