Help on ACS
saquib.tandel
Hi Gurus,
I have just installed ACS 4.0 and added Routers / Firewall / AP for authentication.
ACS uses AD as exernal Database.
AP uses 802.1x
All seems to work-well,
but want to restrict access to Firewall/Routers to a specific Active Directory Group and associate with a group in ACS
Can someone help with steps.
Jagdeep Gambhir
Level 10
Level 10
For that you need to set up a feature called Network access restrictions, NAR
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_white_paper09186a00801a8fd0.shtml
~JG
Do rate helpful posts
Thanks Gambhir..
Is there a step-by-step guide or document to NAR and its more extensive usuage information....
I searched without Luck....
Do let me know on this....
Thank You. It works
