How to auto redirect on success of temporal posture check
Tim Baum
Customer is customizing the flow of their guest portal and wants to have the temporal posture check auto redirect on completion. There does not seem to be a setting in the client provisioning portal page to do this. Is there another way to have the session go to the original request URL?
And is there a way to alter the time (10 sec) for checking for the temporal agent? The agent is never going to be there for this situation and the preference is to skip the 10 sec search and just go to the download option.
Timothy Abbott
Original URL redirect is a function of either the BYOD or guest portals will only work if the NAD supports it as not all of them do. Unfortunately, there is no way to modify the agent detection timer.
-Tim
Timothy Abbott
-Tim
