How to Configure cisco ise 2.3 for wireless 802.1x authentication with active directory
Dout1142
Hello Community,
This is my first time configuring the ISE 2.3.
My Scenario has ISE 2.3, WLC 3504, the users should authenticate throught AD.
I would like to know how to configure the policy in ISE 2.3. I have been searching on internet, but the most information is abot 1.x , 2.1 and 2.2.
Anybody knows a configuration file or a step by step?
Thanks in advance
Mike.Cifelli
See here: https://www.cisco.com/c/en/us/td/docs/security/ise/2-3/admin_guide/b_ise_admin_guide_23/b_ise_admin_guide_23_chapter_0100101.html
That should help you. Also, check out: labminutes.com/video/sec for good free tutorials.
Cheers!
Mike.Cifelli
Cheers!
Thanks for your response,
I was able to configure the policy set following the link, however I am on this scenario.
1. When I search the wireless network and click on the name I get this message.
              Can't connect to this network.
    I click on close botton and try again.
2. When I try to connect again, the SSID prompts for the credentials, I enable the check mark, the username and password is filled out automatic.
My questions is;
how can I avoid to insert the username and password?
I think that should be automatic.
Any idea?
Thanks and best Regards!!
For windows 7, https://community.cisco.com/t5/wireless-mobility-documents/peap-authentication-configuration-example-for-windows-7/ta-p/3127408 . It still applies for windows 10 though.Check this section "If desired, check Automatically use my Windows logon name and password (and domain if any) to enable the Microsoft PEAP supplicant to use the Windows logon name for PEAP authentication. This enables the user to log in to the wireless network using their Windows credentials."
