How to set up Cisco ISE to auto-restart after a power outage
Network_Newbie
Hello ISE experts,
May I ask how to set up Cisco ISE to auto-restart after a power outage? Thanks in advance.
My Cisco ISE Version is 3.1.0.518 with Patch 6
Jerry
5 Replies 5
marce1000
 - There is not much to setup  ,  you don't tell for instance if you are using VM or appliance(s) based solution for ISE ; as any computer , it will boot up again and start the ISE services ; perhaps best is to check on the ISE nodes afterwards with the CLI command :
                                       show application status ise
 M.
Sorry Sir my bad. I'm using Cisco appliance UCSC-C220-M5 (version:C220M5.4.2.3c.0).
I can find out the option of "Advanced Power Management Configuration" from BIOS setup page under Advanced --->Socket Configuration, however, there is nothing configuration or option available for automatic power on.
Thank you Sir. By following this power restore policy config guide, I have configured and tested this auto-power on feature of Cisco UCSC appliance successfully.
