Is ISE agent required for PC when configuring monitor mode in switches?
getaway51
Level 2
Level 2
Do I need to use agent in PC when configuring monitor mode in switches?
Francesco Molino
I believe your taking about implementing ise for dot1x in monitor mode.
The answer is no need of any agent on your device, just use the native supplicant.
Below an official doc for this mode:
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/design-zone-security/howto_21_monitor_mode_deployment_guide.pdf
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Many thanks for yr advise. May I know where the traffic of "monitor mode" will in processed? which policy set in ISE will determine traffic of "monitor mode"? or how can i determine in ISE wht to do with these "monitor mode" traffic?
