Ise 2.0 Client Machine not Redirect URL Wired Dot1x
hello staff i need help about the ise 2.0.0.306, i use the patch 6 has basic license ISE-VM-K9, i am a user Windows 10 has client machines and the machines is not forwarded to the URL so automatica so manually.
I'll share a few things to consider
29 Replies 29
Filip Po
I assume that you using a browser to redirect. The dACL will replace the pre-authentication ACL/PACL you have configured on the switchport. Traffic must be first allowed via dACL then it will hit redirect ACL.
Precisely: ACS ACL:    xACSACLx-IP-PCs_ACL_REMEDIATION-5b35ebba
Filip
Hello Philip can you be more specific?, what they suggest is to place the ACL of the redirect on switch at the port where this machine customer?
Your dACL does not contain the same lines as your ACL for redirect.
Your packet TCP/80 or TCP/443 do not get to ACL for redirect, because dACL will deny it by rule No.11.
I do not see permit tcp any any eq http and permit tcp any any eq 443 in your dACL.
Your dACL:
Extended IP access list xACSACLx-IP-PCs_ACL_REMEDIATION-5b35ebba (per-user)
1 permit udp any any eq bootps
2 permit udp any any eq domain
3 permit tcp any any eq domain
4 permit icmp any any echo
5 permit icmp any any echo-reply
6 permit tcp any host ISE_IP eq 8443
7 permit tcp any host ISE_IP eq 8905
8 permit tcp any host ISE_IP eq 8909
9 permit udp any host ISE_IP range 8905 8906
10 permit udp any host ISE_IP eq 8909
11 deny ip any any
Hi Filip, What is sugeres:
my dacl :
11 permit tcp any any eq 80
12 permit tcp any any eq 443
13 deny ip any any
AND my acl:
ip access-list extended CORPORATE_REDIRECT
permit tcp any any eq www
or may ACL only have:
deny ip any any
Hi Filipi,I had already put the lines to permit tcp any any for the ports 80 and 443 on my DACL and nothing happened.
Is your DNS in place for ISE_NAME, if not change to IP address
BB
BB
Hi Balaji, I had done this exchange:
ISE_IP fot ISE_NAME not resolve.
Is the ip http server and ip http secure-server in enabled on your switch?
That's a prerequisite for redirection to work.
Hi Marvin, I have these prerequisite on my Switch, ip http server and ip http secure-server.
Manual so i can paste the url on the client machine, more so automatica does not happen.
Does the RADIUS live log show that a redirect URL is being sent when the client initially connects?
If it doesn't, then you most likely have a problem with your authorization policy
From your initial output of an authenticated session, under the Server Policies section you do not have the URL Redirect: - this should include the ISE FQDN and session ID.
Your output:
Server Policies:
Vlan Group: Vlan: 35
URL Redirect: ** ISE FQDN SHOULD BE HERE **
URL Redirect ACL: CORPORATE_REDIRECT
For example from my lab:-
Server Policies:
         URL Redirect:  https://ISE24.lab.local:8443/portal/gateway?sessionId=C0A80A0200000018000BC42A&portal=3fab66d0-2e02-11e8-ba71-005056872c7f&action=cwa&type=drw&token=4ac3647ccda92d8717d3e1c5721c7d29
     URL Redirect ACL:  REDIRECT_ACL_CWA
              ACS ACL:  xACSACLx-IP-PERMIT_ALL_TRAFFIC-57f6b0d3
Marvin is probably on the right track, check your Authorization Profiles, please provide a screenshot and we can review.
Hi Please find attached the sharing
I've reviewed your output and done some testing, your Authz Profile has the entries I'd expect and your switch configuration you provided looks ok. I don't have ISE 2.0 P6 nor your switch so cannot mirror your exact scenario.
Have you tried testing on another switch model or the 2960x with another (newer) IOS version? I noted you are not running the latest version.
Thanks,do you have any suggestion about correct ios for my switch?
The little time I upgrade my switch IOS version 15.0 to 15.2.
