ISE 2.2 Web GUI password problem
bsgdsube1
Community Member
I've installed ISE 2.2 on sns-3415. But after the setup process, I couldn't login Web GUI with the username and password which I specify in setup process. Unlike Web gui, I can login CLI with the username and password. I know the application password reset commands via CLI, and I've reset password successfully but that didn't work either.  i can still login CLI but cant login Web gui.
5 Replies 5
Aphea
Community Member
Hello bsgdsube1,
Could you go to CLI and issue this command
ise01#show application status ise
Please share me your output.
Thank,
bsgdsube1
Community Member
Most probably there were something like a timeline for the lock out process. Because when I've tried to log in today, I could log in fine with the new password. So thank you apheasomsovan for your help, I solved my problem.
Aphea
Community Member
Bravo, Best luck.
Faisal2011
Visitor
hi, please can you share us how to fix it
