ISE CA certificate key usage bit for key Encipherment or Key Agreement missing
DammeneSalah_2
Generate the CA certificate from Microsoft Server Window 2008 R2, create  a new web server certificate template, add the client authentication on  the extension tab for EKU. Other option remain default setting.
I trying to import this certificate into Cisco Identity Service Engine  it showing error. Well, the CSR is generated from this appliance  somehow, key length is 2048 and SHA-256, save as .pem format.
The error it show as
"Certificate does not have required key usage (key usage bits for KeyEncipterment or KeyAgreement are missing)"
Please advice, thanks
Salah
Peter Koltl
Level 7
Level 7
The Server authentication EKU is needed, not the Client authentication.
