10-31-2023 09:47 AM
I would like someone to guide me if this scenario is possible or not as I am new to ISE.
Switches are 3750 as Access and 9300 as core.
current situation: I have a lab with 30 pcs connected to 3750 Switch. Users are ISE authenticated (done by an engineer who left the company). Lets call the user here A.
I would like to create another user lets call it user B. (I would like to know how can I do that).
When user A login to one of the pcs he would get an ip from subnet 10.1.1.0/24.
When user B connects to that pc he would get an ip from subnet 10.1.2.0/24.
Could someone explain to me how to do that? I know the part where I need to create two vlans and trunk them on that pc port. the pc has only one NIC.
If its possible to do that through ISE and dhcp could you please tell me the steps I need to do?
Solved! Go to Solution.
11-01-2023 02:13 PM
NAC configuration is not supported on a trunk port, so you would need to use an access port and apply dynamic vlan assignment as an authorization result. See the Cisco ISE Secure Wired Access Prescriptive Deployment Guide for detail and examples.
If you're new to ISE, you might also want to review many of the topics covered in the Webinars and other learning materials found at https://cs.co/ise-resources#Learn
11-01-2023 02:56 PM
The switch has the ability to receive a dynamic VLAN assignment from the RADIUS server (ISE, in this case) and will change the VLAN for that active session. This is a basic functionality of any NAC solution and has been around for over a decade.
Please review the documentation and learning materials I shared in the previous post.
11-01-2023 02:13 PM
11-01-2023 02:21 PM
Hi Greg,
If NAC is not supported on trunk ports, how can I add two different vlans on the same ports?
11-01-2023 02:56 PM
