ISE features matrix with IOS Lan Base vs IP Base licensing on NADs
cfitzgerald
We have a fleet of 3650 switches running Lanbase license. I just discovered today that the Device Profiling (Device Sensor) features of ISE require the IP Base license on the switches. I am trying to find out what other features of ISE require IP Base, but I can't find what I need. Does anybody have any ideas? Thanks.
I could not find this information in public documentation, but I did find an previous TAC case in which the TAC engineer confirmed the following:
"NAC when used for posture flow, requires DACL configuration on the ISE. The DACLs are not applied on the switch interfaces if the switch uses LAN base license."
TrustSec also requires the IP Base feature set as per the Platform and Capability Matrix
As such, you would need to upgrade to the IP Base license to take advantage of the more advanced ISE features.
Cheers,
Greg
6 Replies 6
HI @Mike.Cifelli,
Thanks for your response, but I've looked at that document before. It confirms that the 3650 switch is compatible with all ISE features, but it does not differentiate between a switch with LAN Base license vs IP Base (or higher).
ISE Device Profiling requires IP Base. But what about TrustSec? Or Posturing?
I don't think you will find a comprehensive list because feature sets have always varied by model. I've never seen one at least.
If you look at the TrustSec matrix, you can see what I'm talking about. In general though, trustsec is a feature found in ip base/network advantage/dna advantage. Some exceptions on the ends, ex. ie series switches, 2960's.
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise-networks/trustsec/software-platform-capability-matrix.pdf
Cheers,
Greg
DACL seems like one of the most basic features of ISE, since it is required for any meaningful application of an AuthZ policy result.
I have been unable to find any reference to DACL in the Feature Navigator for the 3650 Platform.
While I can't speak to the feature navigator, I am 100% on DACLs being supported on 3650's.
