ISE Integration with Entra-joined Devices/Users
GregoryLeggett
My organization is working on migration path to Win11 (Entra joined), with hybrid user accounts. According to the below posting, it was mentioned that TEAP (EAP-TLS) is not supported for Computer authentication or EAP-Chaining.
Cisco ISE with Microsoft Active Directory, Azure AD, and Intune
I have two questions about this;
  1. Is this a limitation of ISE or with Windows11 being Entra joined?  If ISE, could you please explain why EAP-Chaining and computer authentication are not supported?
  2. We are currently using TEAP to solve the "chick and egg" problem outlined in the below posting.  If TEAP cannot be used in an Entra joined environment, then what options are available to ensure that a user logging into a computer for the first time is able to build a user profile with certificate issuance, for user authentication?
    EAP-TEAP: First time user login/chicken & egg scenario
@Greg Gibbs
17 Replies 17
The feature for Device Authorization against Entra ID is no longer expected to be available until the release of ISE 3.5. No ETA can be provided, but you're likely looking at around June-July timeframe. It will likely be back-ported to a patch in 3.4 that will release after the FCS of 3.5.
Thanks for the info Greg.
Hi ,
I am bit confused... if TEAP(EAP-TLS) and EAP-FAST(EAP-TLS) with EAP Chaining are supported for this Entra AD flow from ISE 3.2 patch 5 and ISE 3.3 patch 1 due to the fix implemented by bugID CSCwd34467
Then what is the use case of Machine authentication function going to be release on ISE 3.5. Without ISE 3.5 can we use this ?
