ISE Nokia Authentication problems
milesmet
Community Member
After research I know this is possibly a Nokia issue, and there are many discussions on this PEAP issue on Nokia, but I wanted to Check from ISE side if anything can be done:
Apple devices, Android & Blackbeerry all connect and authenticate ok, through AP's > WLC (5508) > ISE > ActiveDirectory
But Nokia's all get error:
12321  PEAP failed SSL/TLS handshake because the client rejected the ISE local-certificate
No matter what configuration I try on the handset
The certificate in use is from Verisign and as mentioned works on other devices
Any idea's what can be done on either Nokia handset or ISE?
ISE logs (correct username coming through:
ISE logs (with different config on handset, which reuslted in username difference from above):
shekharmore003
Level 3
Level 3
No. this is not an ISE issue. I think you have to install certficate manually on Nokia devices .
