ISE not sending Access-reject for IOS clients for putting wrong password.
Gagandeep Singh
Hi Team,
ISE set to 0 retries for PEAP inner methods because of below reason from some internal documentation.
  • PEAP Password Retries: In a non-Microsoft environment such as a wireless environment with many Apple or Android devices set PEAP Password Retries to 0. Currenly devices that do not support PEAP Password Retries will stop responding once the retry message is received and instead start a new EAP session.  Since an Access-Reject is never received by the WLC client exclusions will never kick in for multiple failed password attempts meaning a device statically configured with a bad password can flood ISE.
I do not see any erroneous debugs from WLC log.
From the latest captures in ISE, it’s clear that ISE detects the wrong password, but I see different flow in case of iPhone vs android.
iPhone:
24212 Found User in Internal Users IDStore
22063 Wrong password
22057 The advanced option that is configured for a failed authentication used
22061 The 'Reject' advanced option is configured in case of a failed authentication
request
11823 EAP-MSCHAP authentication attempt failed
12305 Prepared EAP-Request with another PEAP challenge
11006 Returned RADIUS Access-Challenge
11001 Received RADIUS Access-Request
11018 RADIUS is re-using an existing session
12304 Extracted EAP-Response containing PEAP challenge-response
11810 Extracted EAP-Response for inner method containing MSCHAP 11815 Inner EAP-MSCHAP authentication failed – Why ISE is not sending Access-Reject from here???
11520 Prepared EAP-Failure for inner EAP method
22028 Authentication failed and the advanced options are ignored
5440
Endpoint abandoned EAP session and started new
Android:
22057   The advanced option that is configured for a failed authentication request is used
22061   The 'Reject' advanced option is configured in case of a failed authentication request
11810   Extracted EAP-Response for inner method containing MSCHAP challenge-response
12917   Expected TLS acknowledge for PEAPv1 protected termination but received another message
       11500 Invalid or unexpected EAP payload received
11504   Prepared EAP-Failure
11003   Returned RADIUS Access-Reject
The only difference found is that if “Authentication Method comes as  dot1x “, ISE will reject it.
If it comes as “MSCHAPv2”, ISE doesn’t reject it. Instead sending another Access-challenge packet.
Need to know the reason behind coming different authentication method.
I have tested in LAB with Iphone6 + with IOS 10.3.3 and got failed authentication with access-reject.
Identity Services Engine
Overview
Event    5400 Authentication failed
Username abcd
Endpoint Id 9C:4F:DA:1B:C5:35
Endpoint Profile
Authentication Policy     Default >> Dot1X
Authorization Policy Default
Authorization Result
Authentication Details
Source Timestamp 2017-08-10 17:41:28.023
Received Timestamp 2017-08-10 17:41:28.024
Policy Server       ISE23
Failure Reason   22063 Wrong password
Resolution Check the user credentials. Also check whether the password is wrong.
Root cause Wrong password
Username abcd
User Type User
Calling Station Id 9c-4f-da-1b-c5-35
Authentication Identity Store Internal Users
Identity Group    User Identity Groups:ALL_ACCOUNTS (default)
Audit Session Id 0ac9e875000000c3598ce117
Authentication Method  dot1x
Authentication Protocol PEAP (EAP-MSCHAPv2)
WLC engineer filed an internal bug "WLC/ISE unable to exclude iOS 10.3.3 client with failed authentication" but they want this thing to be validated on ISE side.
Gagan
Craig Hyps
Level 10
Level 10
Per the message "Endpoint abandoned EAP session and started new".  This is saying that before auth event came to a conclusion (pass/fail), endpoint started new EAP session. ISE can return access reject for these cases by using suppression with reject option.  This will allow client exclusion to kick in on WLC.
Craig
Craig Hyps
Level 10
Level 10
Craig
I have this same problem and even configuring suppression with reject option, ISE does not send rejects, the request timeout so exclusion does not kick in, causing ultimately that AD password locks out...
b1230912
I know this is an old threat but I seem to be experiencing a very similar issue with iOS devices. Can anyone provide clarification on what actually solved this issue? I see the note about suppression and rejection, but what was the actual fix?
I opened a case and no solution... They told me it is an IOS issue because they cannot control how the client behaves, so if the client stops responding and causes the timeout and the wrong password trigger, they cannot do anything about it...  I told them to get in contact with Apple to fix the issue, good luck with that...
