10-18-2017 04:11 AM
Hi All,
Can any one through some light on detailed process that how can we install on 3595 Cisco appliance, ISE PAN (Primary) and MnT (Secondary) on the same box. Will it be one installation or ????
Then on second 3595 PAN (secondary) and MnT ( Primary) on the same box???
Then other two boxes both 3595 needs to be installed as PSNs???
Br,
Solved! Go to Solution.
10-18-2017 05:22 AM
Navigate to Administration > System > Deployment. You can choose the personas to be used on this page. You can even set the Roles as Primary and Secondary.
The Admin Guide is very helpful in this aspect:
10-18-2017 05:22 AM
