ISE passiveID with same 802.1x AD join point
eugeniodesideri
hi y'all ,
i have a cisco ise 2.7 distributed deployment 2pan+2psn:
i want to add passiveID function in order to share metadata (user mapping tru PXGRID )
When i am going trough the wizard , i am not able to add in passiveID tab my Active Directory join point , cause it's already in use by 802.1x identity source.
If i try to go trough manual configuration ( external id source ----> select my ad join point ---> ADD DC ) the fetching
of the DCs keeps failing .
Cannot find nothing about this issue on the guide.
Somebody saw faced the same issue ?
thanks
Eugenio
You should absolutely be able to easily do what you are trying.  Looks like a call to TAC is in order on this one.
5 Replies 5
eugeniodesideri
here's a couple of screenshot for a better understanding
Charlie Moreton
What patch is installed on 2.7?
Have you gone through the Active Directory Requirements to Support Easy Connect and Passive Identity services ?
thx for answering ----
I got a patch 4 installed  .
- yes i did , plus my cisco ISE deployment is behind the same interface where the AD resides.
ok thanks i will forward the issue to a TAC guy
