- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-06-2022 07:35 AM
hi y'all ,
i have a cisco ise 2.7 distributed deployment 2pan+2psn:
i want to add passiveID function in order to share metadata (user mapping tru PXGRID )
When i am going trough the wizard , i am not able to add in passiveID tab my Active Directory join point , cause it's already in use by 802.1x identity source.
If i try to go trough manual configuration ( external id source ----> select my ad join point ---> ADD DC ) the fetching
of the DCs keeps failing .
Cannot find nothing about this issue on the guide.
Somebody saw faced the same issue ?
thanks
Eugenio
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-08-2022 05:22 AM
You should absolutely be able to easily do what you are trying. Looks like a call to TAC is in order on this one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-06-2022 08:02 AM
here's a couple of screenshot for a better understanding
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-07-2022 06:35 AM
What patch is installed on 2.7?
Have you gone through the Active Directory Requirements to Support Easy Connect and Passive Identity services ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-07-2022 07:46 AM
thx for answering ----
I got a patch 4 installed .
- yes i did , plus my cisco ISE deployment is behind the same interface where the AD resides.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-08-2022 05:22 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-13-2022 05:40 AM - edited 04-13-2022 05:42 AM
ok thanks i will forward the issue to a TAC guy
