ISE posture using Meraki MS switches
manvik
Level 3
Level 3
Has anyone done Posture for endpoint devices like laptop, desktop etc with Meraki MS switches in the network. Posture conditions are Domain joined, AV etc.
Should 802.1x be configured on switches for this? It's ok if nay system is connected to nay port in the switch.
Once posture conditions are met they should be permitted to the network.
manvik
Level 3
Level 3
6 Replies 6
marce1000
 - FYI : https://community.cisco.com/t5/security-knowledge-base/how-to-integrate-meraki-networks-with-ise/ta-p/3618650
 M.
should 802.1x configured on switches for the basic ISE posture to work.
are there any configuration document for Meraki switch config for ISE posture.
manvik
Level 3
Level 3
when a user first time connects to local network, how can they redirected to the ISE portal to download and install ISE agent. Whenever a new user connects he/she needs to be redirected to download and install ISE posture agent, once posture is successful they'll be permitted to the network.
Thanks in advance.
any help on this please.
manvik
Level 3
Level 3
There' a comprehensive document available in Meraki community - https://community.meraki.com/t5/Switching/Meraki-MS-Wired-Posture-with-Cisco-ISE/td-p/220229
