ISE Profilinh and Thin Clients
Vice Lacmanovic
I have ISE 1.2 and HP T610 thin client on the network
802.1x authorization is working correctly but clients are profiled as generic HP-devices or HP printers
I don't know how to create custom profiling policy for 'HP-Thin-Client' device.
What OUI conditions to assign for HP T610 clients?
Thanks in advance,
Vice
Saurav Lodh
Level 7
Level 7
Refer to Profiler feed service from below
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/user_guide/ise_user_guide/ise_prof_pol.html#wp1891315
***profile feed services require advance license
Saurav Lodh
Level 7
Level 7
I have advanced license
Also I checked Feed Service, it is enabled but there is no updates listed under 'Update Information and Options'
I have configured external syslog server but I don't know which logging categories needs to be enabled to get syslog messages from Profiler Feed Service
Thanks in advance,
Vice
I found it
logging category for feed service is under administrative and operational audit
Vice,
any chance you managed to get a decent way of profiling these things?
I'm stuck at DHCP options, but there's really not much else I can think of and it's not nearly enough.
Really annoying, HP thinclients...
