ISE Showing successful dot1x, switches swapping for wired APs
jbulloch
Good morning/evening/time of day,
In our current environment our "back end" team and our "wireless" team recently converted our AP's from MAB authentication to 8x. The majority of our AP's converted over fine and are functioning without fail. These AP's that fail show correct dot1x in ISE but on switch will show constantly flipping between dot1x which will fail, then to mab. I can't find a difference. We can allow MAB on the ise profile and it will auth but the goal is to keep them to dot1x.
I can run tcpdump from ise and use the radius t/s tool in the diagnostics tools and see the requests hitting ISE. I can also run dot1x debug from the switch and i receive this (ntp time has since been corrected) so it appears to be talking to the server.  Running an aaa test from the switches in question with a functional account is successful. A device tracking/sensor profile is also feeding ISE the APs LLDP information for policy sorting.
Am i missing something simple here or could someone suggest further troubleshooting i may be overlooking?
Mar 24 19:43:24.002 edt: dot1x-sm:[2462.cecb.04fe, Gi0/2] Posting EAPOL_EAP for 0x3E000FDE
Mar 24 19:43:24.002 edt: dot1x_auth_bend Gi0/2: during state auth_bend_request, got event 6(eapolEap)
Mar 24 19:43:24.002 edt: @@@ dot1x_auth_bend Gi0/2: auth_bend_request -> auth_bend_response
Mar 24 19:43:24.002 edt: dot1x-sm:[2462.cecb.04fe, Gi0/2] 0x3E000FDE:entering response state
Mar 24 19:43:24.002 edt: dot1x-ev:[2462.cecb.04fe, Gi0/2] Response sent to the server from 0x3E000FDE
Mar 24 19:43:24.002 edt: dot1x-sm:[2462.cecb.04fe, Gi0/2] 0x3E000FDE:request response action
Mar 24 19:43:24.023 edt: dot1x-sm:[2462.cecb.04fe, Gi0/2] Posting EAP_REQ for 0x3E000FDE
Mar 24 19:43:24.023 edt: dot1x_auth_bend Gi0/2: during state auth_bend_response, got event 7(eapReq)
Mar 24 19:43:24.023 edt: @@@ dot1x_auth_bend Gi0/2: auth_bend_response -> auth_bend_request
Mar 24 19:43:24.023 edt: dot1x-sm:[2462.cecb.04fe, Gi0/2] 0x3E000FDE:exiting response state
Mar 24 19:43:24.023 edt: dot1x-sm:[2462.cecb.04fe, Gi0/2] 0x3E000FDE:entering request state
Mar 24 19:43:24.023 edt: dot1x-ev:[2462.cecb.04fe, Gi0/2] Sending EAPOL packet
Mar 24 19:43:24.023 edt: dot1x-registry:registry:dot1x_ether_macaddr called
Mar 24 19:43:24.023 edt: dot1x-ev:[2462.cecb.04fe, Gi0/2] Sending out EAPOL packet to MAC 2462.cecb.04fe
Mar 24 19:43:24.027 edt: dot1x-packet:EAPOL pak Tx - Ver: 0x3 type: 0x0
Mar 24 19:43:24.027 edt: dot1x-packet: length: 0x001E
Mar 24 19:43:24.027 edt: dot1x-packet:EAP code: 0x1 id: 0x4E length: 0x001E
Mar 24 19:43:24.027 edt: dot1x-packet: type: 0x37
Mar 24 19:43:24.027 edt: dot1x-packet:[2462.cecb.04fe, Gi0/2] EAPOL packet sent to client 0x3E000FDE
Mar 24 19:43:24.027 edt: dot1x-sm:[2462.cecb.04fe, Gi0/2] 0x3E000FDE:response request action
Mar 24 19:43:24.041 edt: dot1x-packet:[2462.cecb.04fe, Gi0/2] Queuing an EAPOL pkt on Authenticator Q
Mar 24 19:43:24.041 edt: dot1x-packet:EAPOL pak rx - Ver: 0x1 type: 0x0
The switch is confiqured as followed:
Interface:
switchport access vlan 253
switchport mode access
switchport block unicast
authentication host-mode multi-domain
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication violation restrict
mab
dot1x pae authenticator
dot1x timeout tx-period 10
storm-control broadcast level bps 20m
storm-control unicast level bps 62m
spanning-tree portfast edge
spanning-tree bpduguard enable
spanning-tree guard root
Global config:
auth mac-move permit
dot1x system auth-control
Triple AAA:
aaa new-model
aaa group server tacacs+ ISE_TACACS
server name ISE-PSN-1
server name ISE-PSN-2
ip tacacs source-interface Vlan2100
aaa group server radius ISE_RADIUS
ip radius source-interface Vlan2100
aaa authentication login TAC_AUTHEN group ISE_TACACS local
aaa authentication enable default group ISE_TACACS enable
aaa authentication dot1x default group ISE_RADIUS
aaa authorization console
aaa authorization config-commands
aaa authorization exec TAC_AUTHOR group ISE_TACACS local if-authenticated
aaa authorization commands 15 TAC_AUTHOR group ISE_TACACS if-authenticated
aaa authorization network default group ISE_RADIUS
aaa accounting update newinfo
aaa accounting auth-proxy default start-stop group ISE_RADIUS
aaa accounting dot1x default start-stop group ISE_RADIUS
aaa accounting exec TAC_ACCT start-stop broadcast group ISE_TACACS
aaa accounting commands 15 TAC_ACCT start-stop broadcast group ISE_TACACS
aaa server radius dynamic-author
client x.x.10.13 server-key 7 054A422A22594C2C1D07051D5A5E577E
client x.x.10.12 server-key 7 041A4F230C344E6B0D1B171843595F50
client x.x.10.11 server-key 7 100F4D3C0602102E08063824757A6061
client x.x.10.10 server-key 7 054A422A22594C2C1D07051D5A5E577E
radius config:
radius-server attribute 6 on-for-login-auth
radius-server attribute 6 support-multiple
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 10 tries 3
radius-server deadtime 15
radius server ISE-PSN-1
address ipv4 x.x.10.12 auth-port 1645 acct-port 1646
key 7 1456562E0F11280E202A213A73415442
radius server ISE-PSN-2
address ipv4 x.x.10.13 auth-port 1812 acct-port 1813
14 Replies 14
You need to auth the AP not wifi client via SW?
This AP is local mode or flex mode?
MHM
Good morning,
Thanks for the response.
The AP's are in a local mode and connect via to a WLC (aruba). We are in this case authing the AP's via ISE before they handle the usual tunnel / exit from the controller of the vlans and the controller handles the clients. This has been working fine for us in MAB auth for ages, and is working fine for us where the AP's are working with 8x.
Arne Bier
As @MHM Cisco World correctly asked, is the WAP configured to be in local mode or Flex - looking at your switch config, the access mode would indicate that you are not in Flexconnect, and your WAPs are creating a CAPWAP tunnel back to the WLC. Hence, access VLAN is all you need. That would be correct in that case.
The command
is strictly speaking only for switchports that need one DATA MAC address, and one VOICE MAC address - check what MAC addresses your're learning on that switch interface
show mac address int gig0/2
and if you only see the MAC address of the Cisco WAP, then you can change the host-mode to
authentication host-mode single-host
But that's not the issue here. The issue is why the WAP is failing 802.1X and you can get that reason in ISE, in Live Logs details. Show us an example of what ISE is reporting when 802.1X fails.  Perhaps those WAPs don't trust the ISE EAP certificate, or the 802.1X supplicant has not been provisioned correctly. In that case, the WAP is doing the right thing, it fails-back to non-802.1X mode and tries again, and again ... until you fix the issue.
Hi arnie,
Thanks for the response.  I deploy auth host-mode multi-domain in my template for user facing ports to support VOIP users. I've never had an issue with it being left on AP ports as there's only one device and no tag/untag going on, so for ease of configuration    it remains. I can confirm that changing it to either of cisco's three options makes no difference, and only the AP's mac is visible on the port.
When i check in ISE endpoints, it reports 8x auth.
The live logs seem to report similar, I've blanked out corporate naming convention per policy.
Overview
Event
5200 Authentication succeeded
Username
<our username>
Endpoint Id
24:62:CE:CB:04:FE
Endpoint Profile
Aruba-AP-515_3560CX
Authentication Policy
WIRED_NETWORK >> EAP-PEAP
Authorization Policy
WIRED_NETWORK >> 0066_Aruba_AP_802.1x_EAP-PEAP
Authorization Result
0066_Aruba_AP
Authentication Details
Source Timestamp
2024-02-01 08:25:17.522
Received Timestamp
Policy Server
ise-psn-1
Event
Username
<Our Username>
Endpoint Id
24:62:CE:CB:04:FE
Calling Station Id
24-62-CE-CB-04-FE
Endpoint Profile
Aruba-AP-515_3560CX
IPv4 Address
x.x.x.x
Authentication Identity Store
<OUR AD>
Identity Group
Aruba-AP-515_3560CX
Audit Session Id
9D8D00EF00000602B583F598
Authentication Method
dot1x
Authentication Protocol
PEAP (EAP-MSCHAPv2)
However, switch is still flapping between the two.
Ok the AP dont run any Radio now and you only auth the AP.
Can i see from SW
Show authentication session interface x details
MHM
Sure thing,
here it is authed over to mab. The dot1x fails over almost immediately.
Interface:  GigabitEthernet0/2
          MAC Address:  2462.cecb.04fe
         IPv6 Address:  Unknown
         IPv4 Address:  x.x.66.187
            User-Name:  24-62-CE-CB-04-FE
               Status:  Authorized
               Domain:  DATA
       Oper host mode:  multi-domain
     Oper control dir:  both
      Session timeout:  1800s (server), Remaining: 1760s
       Timeout action:  Reauthenticate
      Restart timeout:  N/A
Periodic Acct timeout:  N/A
       Session Uptime:  71s
    Common Session ID:  9D8D00EF0000061CB5CCF94F
      Acct Session ID:  0x000012E9
               Handle:  0x8D00022A
       Current Policy:  POLICY_Gi0/2
Local Policies:
        Service Template: DEFAULT_LINKSEC_POLICY_SHOULD_SECURE (priority 150)
      Security Policy:  Should Secure
      Security Status:  Link Unsecure
Server Policies:
           Vlan Group:  Vlan: 66
              ACS ACL:  xACSACLx-IP-Aruba_AP_MAB_3560-63c6bae1
Method status list:
      Method            State
      dot1x              Stopped
      mab                Authc Success
No need friend
You mention that you change the AP from MAB to 802.1x but as I see the auth success is for MAB and 802.1x is stopped.
MHM
Common Session ID:  <<- there number appear here in show authentication session check it in ISE live logs.
MHM
Yes, that is my point of confusion. The ISE live logs (and end point details) report dot1x, but the switch is constantly trying to do dot1x and flapping between dot1x and mab. Of course, this means tunnel to controller is never built.
Has this is only occurring with a handful of our APs, i am starting to think it is a issue with the particular AP config. However person in charge of this insists the APs are all built from the same template so i am doing my due diligence to say it is not the switches.
I dont think it issue of AP is issue of ISE the wire conditional you use for auth is same and hence the MAB is auth and then 802.1x
that my guess
but you can sure by look to common session ID, if it same and the auth-policy is for PEAP then OK if the common session ID is different then the ISE is auth the AP via MAB.
MHM
For instance i just moved over to my SSH workstation across the room, and same AP is now:
         IPv4 Address:  Unknown
            User-Name:  1nnaruba
               Status:  Authorized
               Domain:  DATA
      Session timeout:  3600s (server), Remaining: 3200s
       Session Uptime:  402s
      Acct Session ID:  0x0000132B
               Handle:  0x8D00022A
Local Policies:
Server Policies:
           Vlan Group:  Vlan: 155
            SGT Value:  16
Method status list:
      Method            State
      dot1x              Authc Success
and the VLAN is change form 66 to 155 (is that OK) if not this can keyfactor to check the issue in ISE
and the dot1x is authc success perfect
MHM
Hi, i'am not sure on the vlan. I don't have ability to see the actual rules built out in ISE.
However the session ID was the same, and when i punched it into live logs i got back both the eap and mab auth back to back. I guess i need to go have a word with our network defense guys about whatever policies they are running.
jbulloch
In additon, here is the authentication log. I've had to remove some coporate information here as well.
Other Attributes
ConfigVersionId
210
DestinationPort
1645
Protocol
Radius
NAS-Port
50102
Framed-MTU
1500
State
37CPMSessionID=9D8D00EF00000602B583F598;38SessionID=ise-psn-1/494795943/10900087;
NetworkDeviceProfileId
b0699505-3150-4215-a80e-6753d45bf56c
IsThirdPartyDeviceFlow
false
AcsSessionID
SelectedAuthenticationIdentityStores
<OUR ID Store>
Internal Users
AuthenticationStatus
AuthenticationPassed
IdentityPolicyMatchedRule
EAP-PEAP
AuthorizationPolicyMatchedRule
EndPointMACAddress
24-62-CE-CB-04-FE
EapChainingResult
No chaining
ISEPolicySetName
WIRED_NETWORK
IdentitySelectionMatchedRule
EAP-PEAP
AD-Error-Details
Domain trust is one-way
AD-User-Resolved-Identities
<our ad id>
AD-User-Candidate-Identities
<our ad id>
TotalAuthenLatency
109
ClientLatency
91
AD-User-Resolved-DNs
 <ad info>
AD-User-DNS-Domain
 <ad info>
AD-Groups-Names
<ad group>
AD-User-NetBios-Name
<ad user>
TLSCipher
DHE-RSA-AES256-SHA256
TLSVersion
TLSv1.2
DTLSSupport
Unknown
HostIdentityGroup
Endpoint Identity Groups:Profiled:Aruba-AP-515_3560CX
Network Device Profile
Cisco
Location
 <loc string>
Device Type
Device Type#All Device Types#Switch
IPSEC
IPSEC#Is IPSEC Device#No
Name
ExternalGroups
S-1-5-21-2039752546-350242969-1258846019-513
IdentityAccessRestricted
false
RADIUS Username
 <user name>
Device IP Address
x.x.x.x
CPMSessionID
Called-Station-ID
04:6C:9D:F8:5D:02
CiscoAVPair
<av pair>
Result
Class
CACS:9D8D00EF00000602B583F598:ise-psn-1/494795943/10900087
Session-Timeout
1800 seconds
Termination-Action
RADIUS-Request
Tunnel-Type
(tag=1) VLAN
Tunnel-Medium-Type
(tag=1) 802
Tunnel-Private-Group-ID
(tag=1) 66
EAP-Key-Name
19:00:00:1d:10:14:d7:7d:26:78:9f:e6:2f:32:09:e5:51:41:4c:c8:b3:d8:e6:bb:db:91:45:5f:70:70:18:30:38:68:d0:a8:6d:94:cd:7d:a3:55:9f:1d:58:33:ba:6d:48:87:2a:b0:83:7c:97:d9:21:7c:e9:f2:5b:fa:5c:9f:0d
cisco-av-pair
ACS:CiscoSecure-Defined-ACL=#ACSACL#-IP-Aruba_AP_MAB-63c6ba1a
MS-MPPE-Send-Key
MS-MPPE-Recv-Key
LicenseTypes
Essential license consumed.
Session Events
Steps
11001
Received RADIUS Access-Request - NNSY_PROD_AD
11017
RADIUS created a new session - nnsy.sy
15049
Evaluating Policy Group - NNSY_PROD_AD
15008
Evaluating Service Selection Policy - nnsy.sy
15048
Queried PIP - NNSY_PROD_AD
11507
Extracted EAP-Response/Identity - NNSY_PROD_AD (2 times)
12756
Prepared EAP-Request proposing TEAP with challenge
12625
Valid EAP-Key-Name attribute received
11006
Returned RADIUS Access-Challenge
11001
11018
RADIUS is re-using an existing session
12301
Extracted EAP-Response/NAK requesting to use PEAP instead
12300
Prepared EAP-Request proposing PEAP with challenge
12625
11006
11001
11018
12302
Extracted EAP-Response containing PEAP challenge-response and accepting PEAP as negotiated
12318
Successfully negotiated PEAP version 0
12800
Extracted first TLS record; TLS handshake started
12805
Extracted TLS ClientHello message
12806
Prepared TLS ServerHello message
12801
Prepared TLS ChangeCipherSpec message
12802
Prepared TLS Finished message
12305
Prepared EAP-Request with another PEAP challenge
11006
11001
11018
12304
12318
12802
12803
Extracted TLS ChangeCipherSpec message
12804
Extracted TLS Finished message
12816
TLS handshake succeeded
12311
PEAP session resumed successfully
15041
Evaluating Identity Policy
15048
Queried PIP - Network Access.EapTunnel
22072
Selected identity source sequence - PEAP
15013
Selected Identity Source - NNSY_PROD_AD
24432
Looking up user in Active Directory - NNSY_PROD_AD
24325
Resolving identity - 1nnaruba@nnsy.sy
24313
Search for matching accounts at join point - nnsy.sy
24359
Incoming identity was not rewritten - 1nnaruba@nnsy.sy
24319
Single matching account found in forest - sy
24323
Identity resolution detected single matching account
24355
LDAP fetch succeeded - nnsy.sy
24458
Not all Active Directory attributes are retrieved successfully - NNSY_PROD_AD
24100
Some of the expected attributes are not found on the subject record. The default values, if configured, will be used for these attributes - NNSY_PROD_AD
22037
Authentication Passed
12312
PEAP fast-reconnect - skipping inner method
12305
11006
11001
11018
12304
24715
ISE has not confirmed locally previous successful machine authentication for user in Active Directory
15036
Evaluating Authorization Policy
24209
Looking up Endpoint in Internal Endpoints IDStore - 1nnaruba
24211
Found Endpoint in Internal Endpoints IDStore
15048
Queried PIP - Session.ANCPolicy
24432
Looking up user in Active Directory - 1nnaruba
24355
24416
User's Groups retrieval from Active Directory succeeded
24355
24458
24100
15048
Queried PIP - NNSY_PROD_AD.ExternalGroups
15048
Queried PIP - Network Access.UserName
15048
Queried PIP - Network Access.AuthenticationStatus
15016
Selected Authorization Profile - 0066_Aruba_AP
11022
Added the dACL specified in the Authorization Profile
22081
Max sessions policy passed
22080
New accounting session created in Session cache
12306
PEAP authentication succeeded
11503
Prepared EAP-Success
11002
Returned RADIUS Access-Accept
