ISE specific interface for Device Admin operation
Hi all;
As far as I know, ISE by default supports RADIUS-based traffic in all interfaces (interfaces other the Gig 0). I want to know that, is this rule also applies for TACACS traffic?
Hi @rezaalikhani
ALL Interfaces can be configured with IP Addr.
RADIUS and TACACS+ can be performed on separate Interface, but listen on ANY Interface.
Guest/Sponsor/My Devices/BYOD Portals can be configured and restricted for specific Interfaces
ISE management is restricted to GigabitEthernet 0
Hope this helps !!!
balaji.bandi
It's the same case with TACACS, too, as far as I know; if you like, you can use a dedicated interface depending on deployment; make sure you have a high availability setup.
https://www.cisco.com/c/en/us/td/docs/security/ise/3-0/install_guide/b_ise_InstallationGuide30/b_ise_InstallationGuide30_chapter_7.html
BB
Hi @rezaalikhani
Hope this helps !!!
