ISE Wired posture problem in redirect
Claudio L. de Matos Jr
Frequent Visitor
Frequent Visitor
Hi guys,
I'm doing a lab ISE/Posture to homologation for our customer, I'm having trouble redirecting the posture provisioning portal, when I manually install the anyconnect posture module and add the .xml file in the "ISE Posture" folder, it worked.
Could you help me please???
- ISE Version 2.4/Patch 14
- Anyconnect/NAM/Posture Version 4.9.04053
- Switch C3650 Version 16.12.1
show run
SW_C3650#show run
Building configuration...
Current configuration : 13034 bytes
! Last configuration change at 21:19:41 UTC Mon May 31 2021 by admin
version 16.12
no service pad
service call-home
platform punt-keepalive disable-kernel-core
hostname SW_C3650
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 9 $9$uYD0YKDDx80j5E$.Q1sxBhvnx63k53r.wy9dU8i8ZPTllB9C9n3Q02/PWY
aaa new-model
aaa group server radius GP_RADIUS
server name ISE
aaa authentication dot1x default group GP_RADIUS
aaa authorization network default group GP_RADIUS
aaa authorization auth-proxy default group GP_RADIUS
aaa accounting update newinfo periodic 1440
aaa accounting network default start-stop group GP_RADIUS
aaa accounting system default start-stop group GP_RADIUS
aaa server radius dynamic-author
client 172.16.0.12 server-key cisco123
aaa session-id common
switch 1 provision ws-c3650-24ps
call-home
! If contact email address in call-home is configured as [email protected]
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr [email protected]
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
ip routing
ip domain name lab.local
ip dhcp excluded-address 172.16.0.1 172.16.0.100
ip dhcp excluded-address 172.16.1.1 172.16.1.100
ip dhcp pool VLAN11
network 172.16.0.0 255.255.255.0
default-router 172.16.0.158
dns-server 172.16.0.10
domain-name abc.local
ip dhcp pool VLAN12
network 172.16.1.0 255.255.255.0
default-router 172.16.1.158
login on-success log
device-sensor filter-list dhcp list DSENSOR_DHCP
option name domain-name-servers
option name host-name
option name requested-address
option name parameter-request-list
option name class-identifier
option name client-identifier
device-sensor filter-list lldp list DSENSOR_LLDP
tlv name system-name
tlv name system-description
tlv name system-capabilities
tlv name management-address
device-sensor filter-list cdp list DSENSOR_CDP
tlv name device-name
tlv name address-type
tlv name port-id-type
tlv name capabilities-type
tlv name version-type
tlv name platform-type
tlv name duplex-type
tlv number 34
device-sensor filter-spec dhcp include list DSENSOR_DHCP
device-sensor filter-spec lldp include list DSENSOR_LLDP
device-sensor filter-spec cdp include list DSENSOR_CDP
device-sensor accounting
device-sensor notify all-changes
epm logging
authentication mac-move permit
no device-tracking logging theft
device-tracking policy TRACKING
prefix-glean
no protocol ndp
no protocol dhcp6
no protocol udp
tracking enable
dot1x system-auth-control
dot1x critical eapol
license boot level ipservicesk9
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
memory free low-watermark processor 79475
username admin privilege 15 secret 9 $9$6OQYWT7M/bNVhU$8doFFwVZ.fnC01bMAd7BXUjp9vaNWPgEVu63yEh2bkk
redundancy
mode sso
transceiver type all
monitoring
lldp run
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data, LOGGING
class-map match-any system-cpp-default
description EWLC control, EWLC data, Inter FED
class-map match-any system-cpp-police-sys-data
description Learning cache ovfl, High Rate App, Exception, EGR Exception, NFL SAMPLED DATA, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
policy-map system-cpp-policy
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
ip address 172.16.14.159 255.255.255.0
negotiation auto
interface GigabitEthernet1/0/1
switchport access vlan 2
switchport mode access
device-tracking attach-policy TRACKING
ip access-group PRE_AUTHE in
authentication event fail action next-method
authentication event server alive action reinitialize
authentication host-mode multi-domain
authentication open
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication violation restrict
mab
dot1x pae authenticator
dot1x timeout tx-period 10
spanning-tree portfast
interface Vlan1
no ip address
interface Vlan11
ip address 172.16.0.158 255.255.255.0
interface Vlan12
ip address 172.16.1.158 255.255.255.0
interface Vlan14
ip address 172.16.14.158 255.255.255.0
interface Vlan15
ip address 172.16.15.2 255.255.255.0
interface Vlan99
ip address 192.168.77.158 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http secure-active-session-modules none
ip http active-session-modules none
ip route 0.0.0.0 0.0.0.0 172.16.15.1
ip route vrf Mgmt-vrf 0.0.0.0 0.0.0.0 172.16.14.158
ip access-list extended PRE_AUTHE
10 permit udp any any eq bootps
20 permit udp any any eq bootpc
30 permit udp any any eq domain
40 permit ip any host 172.16.0.12
50 permit ip any host 172.16.0.10
60 deny ip any any
ip access-list extended UNKNOWN
10 deny udp any any eq bootps
20 deny udp any any eq bootpc
30 deny udp any any eq domain
40 deny ip any host 172.16.0.12
50 permit ip any any
ip radius source-interface Vlan11
ip access-list standard 1
10 permit any
ip access-list standard 2
10 deny any
radius-server attribute 6 on-for-login-auth
radius-server attribute 6 support-multiple
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server attribute 31 mac format ietf upper-case
radius-server attribute 31 send nas-port-detail
radius-server dead-criteria time 30 tries 15
radius-server retransmit 5
radius-server timeout 7
radius-server deadtime 30
radius server ISE
address ipv4 172.16.0.12 auth-port 1645 acct-port 1646
key cisco123
control-plane
service-policy input system-cpp-policy
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login authentication LOCAL
line vty 5 15
mac address-table notification change
SW_C3650#show authentication sessions interface gigabitEthernet 1/0/1 details
Interface: GigabitEthernet1/0/1
IIF-ID: 0x1B57FDDD
MAC Address: 18d6.c71f.196e
IPv6 Address: Unknown
IPv4 Address: 172.16.1.101
User-Name: user01
Status: Authorized
Domain: DATA
Oper host mode: multi-domain
Oper control dir: both
Session timeout: N/A
Common Session ID: AC10009E0000000DC4812006
Acct Session ID: Unknown
Handle: 0x11000003
Current Policy: POLICY_Gi1/0/1
Local Policies:
Service Template: DEFAULT_LINKSEC_POLICY_SHOULD_SECURE (priority 150)
Security Policy: Should Secure
Security Status: Link Unsecured
Server Policies:
Vlan Group: Vlan: 12
URL Redirect ACL: UNKNOWN
URL Redirect: https://lab-ise001.abc.local:8443/portal/gateway?sessionId=AC10009E0000000DC4812006&portal=40f01bd0-2e02-11e8-ba71-005056872c7f&action=cpp&token=0307268d7ed20b2d3597a92cff9fed0f
ACS ACL: xACSACLx-IP-DACL_UNKNOWN-60b3ca7a
Method status list:
Method State
dot1x Authc Success
SW_C3650#
SW_C3650#show ip access-lists UNKNOWN
Extended IP access list UNKNOWN
SW_C3650#
SW_C3650#show ip access-lists xACSACLx-IP-DACL_UNKNOWN-60b3ca7a
Extended IP access list xACSACLx-IP-DACL_UNKNOWN-60b3ca7a
1 permit udp any any eq domain
2 permit udp any any eq bootps
3 permit udp any any eq bootpc
5 permit ip any host 172.16.0.12
7 deny icmp any host 172.16.0.10
8 deny ip any any
SW_C3650#
Greg Gibbs
There are a number of variables with Posture, so the switch configuration would not be enough information to provide guidance. As a starting point, I would suggest you review the following guides and compare them to your lab setup.
ISE Posture Style Comparison for Pre and Post 2.2
ISE Posture Prescriptive Deployment Guide
There are also some LabMinutes videos that walk through the redirect-based Posture flow in ISE 2.2:
https://www.labminutes.com/video/sec/ISE
Greg Gibbs
