Issue Handling Dot1x Failures with CPL
paul
Level 10
Level 10
I am having a strange issue that I can't explain why CPL is not handling correctly.  We are rolling out ISE in closed mode with CPL.  If the devices happens to have the Wired Auth service enabled the device will briefly get let on with my MAB catch all rule, but then Dot1x will fail and the device will get blocked.  The client is not trusting the ISE server which is expected as we haven't rolled out any GPO policies yet.
So the client sees this:
If the client hits "Connect" the switch will stop Dot1x as expected and the device will stay on the network via my MAB catch all rule.
If the client hits "Don't connect", hits the X to close out the window or doesn't respond the prompt the switch auth will initially look like this:
SC-A29-A116#show access-session int gig 2/13 det
            Interface:  GigabitEthernet2/13
          MAC Address:  a44c.c8e9.33b8
         IPv6 Address:  Unknown
         IPv4 Address:  10.12.29.107
            User-Name:  A4-4C-C8-E9-33-B8
               Status:  Authorized
               Domain:  DATA
       Oper host mode:  multi-auth
     Oper control dir:  in
      Session timeout:  65000s (server), Remaining: 64970s
       Timeout action:  Reauthenticate
      Restart timeout:  N/A
Periodic Acct timeout:  N/A
    Common Session ID:  0A0C0074000003C952FB4EAC
      Acct Session ID:  0x0000B761
               Handle:  0x310002CA
       Current Policy:  ISE_AUTH
Local Policies:
Server Policies:
              ACS ACL:  xACSACLx-IP-Wired_Monitor_Hostname_Exists_In_AD-5adf88eb
Method status list:
       Method           State
       dot1x            Running
       mab              Stopped
The MAB rule is still in effect and I can ping the device. Eventually the Dot1x will fail and it goes to this:
            User-Name:  host/xyx.company.com
               Status:  Unauthorized
               Domain:  DATA
      Session timeout:  N/A
    Common Session ID:  0A0C0074000003C752F8FE5C
      Acct Session ID:  0x0000B749
               Handle:  0x270002C8
Local Policies:
Method status list:
       Method           State
       dot1x            Authc Failed
       mab              Stopped
At this point the user has no access to the network because we are in closed mode.    The switch correctly logs the Auth fail:
May 18 14:08:24.380 EDT: %DOT1X-5-FAIL: Authentication failed for client (a44c.c8e9.33b8) on Interface Gi2/13 AuditSessionID 0A0C0074000003C752F8FE5C
My CPL accounts for Dot1x fail but it doesn't seem to be kicking in after this type of Dot1x fail:
!***CPL***
ip access-list extended PERMIT_ANY
  permit ip any any
service-template CRITICAL_ACCESS
  description Apply when ISE is unavailable to permit traffic and allow voice vlan
  access-group PERMIT_ANY
  voice vlan
class-map type control subscriber match-all AAA_DOWN_UNAUTHD_HOST
  match result-type aaa-timeout
  match authorization-status unauthorized
class-map type control subscriber match-all AAA_DOWN_AUTHD_HOST
  match authorization-status authorized
class-map type control subscriber match-all DOT1X_FAILED
  match method dot1x
  match result-type method dot1x authoritative
class-map type control subscriber match-any IN_CRITICAL_AUTH
  match activated-service-template CRITICAL_ACCESS
class-map type control subscriber match-none NOT_IN_CRITICAL_AUTH
  match activated-service-template CRITICAL-ACCESS
policy-map type control subscriber ISE_AUTH
  event session-started match-all
    10 class always do-all
      10 authenticate using dot1x priority 10
      20 authenticate using mab priority 20
  event violation match-all
      10 restrict
  event agent-found match-all
  10 terminate mab
      20 authenticate using dot1x priority 10
  event authentication-failure match-first
    10 class AAA_DOWN_UNAUTHD_HOST do-until-failure
  10 activate service-template CRITICAL_ACCESS
  20 authorize
  30 pause reauthentication
  40 terminate dot1x
  50 terminate mab
20 class AAA_DOWN_AUTHD_HOST do-until-failure
  10 pause reauthentication
  20 authorize
    30 class DOT1X_FAILED do-all
  10 terminate dot1x
  event aaa-available match-all
10 class IN_CRITICAL_AUTH do-until-failure
  10 clear-session
20 class NOT_IN_CRITICAL_AUTH do-until-failure
  10 resume reauthentication
The Dot1x fail definitely works if the client is not running Dot1x at all, but doesn't seem to work in this case.
Is this working as designed?  The legacy ISE template doesn't have this issue.
I am probably going to open a TAC case, but wanted to post here as well.
kvenkata1
Hi Paul,
On the switch C3PL configuration - Did you configure it from scratch or converted from a working IBNS 1.0 configuration? If it is the former, I would try the conversion option as documented in page 2.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ibns/configuration/xe-3se/3850/ibns-xe-3se-3850-book/san-cntrl-pol.pdf
If you have already tried the conversion option please work with TAC for a resolution.
- Krish
It is from scratch starting with the original 3850 CPL document and adding in components of IBNS 2.0. These are all fresh installs that we converted to new-style before any configuration was applied.
Ahh I think I figured it out and probably something that should be added to the IBNS template. The switch was treating it as a dot1x timeout and not triggering the failure. I had to add this:
class-map type control subscriber match-all DOT1X_TIMEOUT
match method dot1x
match result-type method-timeout
10 restrict
10 terminate mab
20 authorize
40 terminate mab
50 terminate dot1x
20 authorize
10 terminate dot1x
40 class DOT1X_TIMEOUT do-all
10 terminate dot1x
I am going to do more testing but that seemed to work nicely.
Great! I am glad it worked out. Please reach to TAC if you need any further assistance.
- Krish
