LANLITE in Dot1x monitor mode?
michael Helmbo
Does LANLITE switches support monitor mode? We can't seem to write the authentication open command under the interfaces.
nspasov
At a min you need "LAN Base" to run that feature. You can check Cisco's "Feature Navigator" to confirm this and any similar queries in the future. I wasn't sure so that is what I used to find out :)
I also found this thread helpful:
https://supportforums.cisco.com/discussion/11078736/lan-lite-image-vs-lan-base-image
Thank you for rating helpful posts!
nspasov
Venkatesh Attuluri
FYI.. LAN lite is not recommended with ISE 1.2  (if you are planning for one)
stanly426
good function!! thanks for all respondent!
