MAB/802.1x and Alkatel IP Phones
Gaj Ana
Hi All
We have a distributed deployment where Alkatel ip-touch phones are authentictaed via MAB. Alkatel ip touch phones has 802.1x enabled by default and the phone tries eapol first and then switch authenticates via MAB which is fine. Once authenticated its working as expected. The issue is the phone keeps on periodic retry after x amount of minutes for 802.1x again which triggers the phone to reboot again and goes via the whole process. This interupts the voice. We could disable 802.1x but its per phone basis. Has anyone came across this issue and found a way to diable globally via the call manager etcc. or any workarounf from ISE/switch side?
G
21 Replies 21
I also really need this certificate for the exact reasons outlined here.  Can anybody tell me where i can get a hold of it?
My vendor is clueless and unable to supply it,
Can somebody please share the "Wired Phones" CA cert?
Octavian
did you get the certificate?
Octavian Szolga
Level 4
Level 4
Yes I did. Back then I exported the "Wired Phones" CA cert fom wireshark.
I don't have 'Alcatel Enterprise Solution' root CA though.
BR,
Octavian
ok, but it is not solution for all ip touch phones, right?
