Showing results forĀ
Search instead forĀ
Did you mean:Ā
mac auth bypass with freeradius problem
I'm experiencing a problem with mac auth bypass in a catalyst 3560, i connect a phone and a pc to a port and both get
authenticated and working but the phone keep reauthenticating and the console show this error:
*Mar  1 02:10:34.221: %MAB-5-SUCCESS: Authentication successful for client (0023.5e1a.6d59) on Interface Fa0/3 AuditSessionID 0A0C001600000030006A91FB
*Mar  1 02:10:34.221: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (0023.5e1a.6d59) on Interface Fa0/3 AuditSessionID 0A0C001600000030006A91FB
*Mar  1 02:10:34.229: %DOT1X_SWITCH-5-ERR_VLAN_EQ_VVLAN: Data VLAN 11 on port FastEthernet0/3 cannot be equivalent to the Voice VLAN AuditSessionID 0A0C001600000030006A91FB
*Mar  1 02:10:34.229: %AUTHMGR-5-FAIL: Authorization failed for client (0023.5e1a.6d59) on Interface Fa0/3 AuditSessionID 0A0C001600000030006A91FB
*Mar  1 02:11:34.954: %MAB-5-SUCCESS: Authentication successful for client (0023.5e1a.6d59) on Interface Fa0/3 AuditSessionID 0A0C001600000030006A91FB
*Mar  1 02:11:34.954: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (0023.5e1a.6d59) on Interface Fa0/3 AuditSessionID 0A0C001600000030006A91FB
*Mar  1 02:11:34.963: %DOT1X_SWITCH-5-ERR_VLAN_EQ_VVLAN: Data VLAN 11 on port FastEthernet0/3 cannot be equivalent to the Voice VLAN AuditSessionID 0A0C001600000030006A91FB
*Mar  1 02:11:34.963: %AUTHMGR-5-FAIL: Authorization failed for client (0023.5e1a.6d59) on Interface Fa0/3 AuditSessionID 0A0C001600000030006A91FB
But the phone didn't lost connection.
Here is the config:
SWITCH:
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa session-id common
system mtu routing 1500
vtp mode transparent
no authentication logging verbose
ip domain-name alturna-net
dot1x system-auth-control
no dot1x logging verbose
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 10
name DATA
vlan 11
name VOICE
vlan 999
name PARKING
ip ssh version 2
interface FastEthernet0/3
switchport access vlan 10
switchport mode access
switchport voice vlan 11
authentication event fail action authorize vlan 999
authentication host-mode multi-auth
authentication open
authentication order mab dot1x
authentication priority mab dot1x
authentication port-control auto
mab eap
dot1x pae authenticator
spanning-tree portfast
interface FastEthernet0/48
switchport trunk native vlan 10
switchport trunk allowed vlan 10,11
switchport mode trunk
interface Vlan10
ip address 10.12.0.22 255.255.255.0
ip classless
ip http server
ip http secure-server
ip sla enable reaction-alerts
radius-server host 10.12.0.21 auth-port 1812 acct-port 1813 key 1234
radius-server vsa send authentication
line con 0
logging synchronous
line vty 0 4
length 0
transport input ssh
line vty 5 15
end
FREERADIUS user file:
20cf30292a13  Auth-Type := "EAP",  Cleartext-Password := 20cf30292a13
        Tunnel-Type = VLAN,
        Tunnel-Medium-Type = IEEE-802,
        Tunnel-Private-Group-id = "DATA"
00235e1a6d59  Auth-Type := "EAP",   Cleartext-Password := 00235e1a6d59
        Tunnel-Type = VLAN,
        Tunnel-Private-Group-id = "VOICE"
Any help will be much apreciated!
0 Replies 0
