Machine Authentication with PEAP on Wireless with ISE1.2
jain.nitin
Level 3
Level 3
Hi All,
We are facing issues while doing machine authentication in ISE1.2 with wireless PEAP authentication. Without machine authentication normal PEAP works very fine but as soon as we enable machine authentication and create policy for machine authentication and in user authentication policy we put condition "was machine authenticated" then it works for some machine properly but does not work for other machines. Its totally random behaviour sometime it stopped working for machines which were authenticated before.
I just want to know if I m missing some configuration or its a bug in ISE. Can some body share step by step configuration for machine authentication with PEAP.
Really It would be a great help.
Ninja
mbilgrav
Level 3
Level 3
Did you Apply service pactch 4?
